EB 006 Version 9
Beertree
Has thanked: 5 times
Been thanked: 5 times
EB 006 Version 9
Post by Beertree »
Hi at all, I just started with Flowcode 6 and the Multiprogrammer EB-006-00-9, supplied by usb. Power LED is on. when I try to Programm the device, i get the following Error.
What is wrong? Using the external supply makes no difference.
(137.74 KiB) Downloaded 6481 times
Re: EB 006 Version 9
Please can you confirm that all the following jumpers are connected horizontally and also let us know what positions they are in?
J15 Target Voltage
J11 Voltage Source
J12-J14 Prog Source
I would recommend these settings for USB based power.
J15 - 5V
J11 - USB
J12-J14 - USB
Beertree
Post by Beertree »
Thank you for the fast response. Using USB-Power does not work either. I now solved the problem myself. When I feed in 5V directly (after the regulator) everything works fine. The board is simply not ok.
john_m0ers
Been thanked: 3 times
Post by john_m0ers »
out of curiosity, what voltage were you using to start with?
thanks
john
Beertree
Post by Beertree »
A bit late, but 5v targetvol. and the walladapter set ro 9v.
