16F1508 PWM Error
Sanjay Singh
Has thanked: 10 times
Been thanked: 3 times
16F1508 PWM Error
Post by Sanjay Singh »
Hi all,
I'm getting "error 1" message while compiling the attached program.
The compiler message is like this,
Target folder: H:\INTERF~1
Source name: H:\Interface\PWM.fcfx
Title:
Description:
Device: PIC.16F.16F1508
Generated by: Flowcode v6.1.2.0
Date: Monday, August 24, 2015 22:21:50
Users: 1
Registered to: ***************
Licence key: ******
http://www.matrixtsl.com
Launching the compiler...
Launching BoostC...
Completed BoostC compilation, return = 1
FINISHED
The oscillator is set external @ 19.660MHz
Kindly help me to resolve this issue.....
San
PWM.fcfx
(6.09 KiB) Downloaded 375 times
Sanjay Singh
Re: 16F1508 PWM Error
Hi all,
Even the "RS232" macro is throwing the "Error 1" while compiling.
There seems to be many issues with the 16f1508.fcdx file
I'm struck halfway in a project & hoping for some help.
Sanjay
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Hi Sanjay,
I'll have a look at updating the CAL for this chip and get back to you as soon as possible.
Leigh
LeighM
Post by LeighM »
Please try this updated PWM CAL,, place in your Flowcode 6\CAL\PIC directory.
Leigh
ps. next the RS232 ....
PIC_CAL_PWM.c
(14.28 KiB) Downloaded 418 times
LeighM
Post by LeighM »
Here's a fix for the 16F1508 UART ...
PIC_CAL_UART.c
(23.32 KiB) Downloaded 437 times
Sanjay Singh
Hi Leigh,
After the update, the RS232 macro is working & the PWM is throwing "error 2"
C:\Program Files\Flowcode 6\compilers\pic\boostc\boostc_16F.exe -v -t PIC16F1508 "PWM.c"
Launching BoostC...
Completed BoostC compilation, return = 0
C:\Program Files\Flowcode 6\compilers\pic\boostc\boostlink_picmicro.exe -ld "C:\Program Files\Flowcode 6\compilers\pic\boostc\lib" libc_16F.lib rand_16F.lib float_16F.lib "PWM.obj" -t PIC16F1508 -d "H:\C_ENTR~1\INTERF~1" -p "PWM" -swcs 6 2
BoostLink Optimizing Linker Version 7.20
http://www.sourceboost.com
Copyright(C) 2004-2013 Pavel Baranov
Copyright(C) 2004-2013 David Hobday
Error: Unresolved external function:'FC_CAL_PWM_ChangePeriod_1(unsigned char,unsigned short)'
Error: Unresolved external symbol, function:FC_CAL_PWM_ChangePeriod_1
failure
C:\Program Files\Flowcode 6\compilers\pic\boostc\boostlink_picmicro.exe reported error code -2
FINISHED
Kindly advice on this issue.
Sanjay
LeighM
Post by LeighM »
Hi Sanjay,
Sorry about that. I fixed our head revision, but it's 2 months since our last release and there have been a few changes in the components (but not yet released).
So I've attached the latest components, these will match with the CAL code.
Please copy these component files to the Flowcode 6 \components directory, might be worth doing a backup of the old versions first :)
Let me know if you have any issues, in which case I'll have to roll back to a previous CAL version, and fix that instead.
Leigh
PWM.fcpx
(7.8 KiB) Downloaded 370 times
cal_pwm.fcpx
(8.08 KiB) Downloaded 369 times
Sanjay Singh
Hi Leigh,
After updating the component, PWM is working fine.
Kindly let me know how to enable RXINT, as the option is not there on the Interrupt macro or provide me any sample working FC program to receive UART data on interrupt.
Sanjay
LeighM
Post by LeighM »
Attached is an updated fcd with a UART interrupt for the 16F1508, place it in your Flowcode 6\FCD\PIC directory.
You will need to create, and specify in the interrupt enable, a new macro to run on interrupt.
This macro will then need to call ReceiveChar and place the character received into a buffer.
To help with that, there is a Circular Buffer component.
I don't have any samples, but a search on this forum will come up with a few, such as
http://www.matrixtsl.com/mmforums/viewtopic.php?p=33484
Leigh
16F1508.fcdx
(15.55 KiB) Downloaded 386 times
Sanjay Singh
Hi Leigh,
Thanks for the update. UART Int is working fine without any issues.
Kindly provide the PWM & UART updates for 16F1509.
Sanjay
LeighM
Post by LeighM »
Thanks for letting us know that it works.
Here is the 16F1509 fcd ...
16F1509.fcdx
(15.55 KiB) Downloaded 310 times
Sanjay Singh
Hi all,
I'm getting "error 1" message while compiling the attached program when SPI is on Channel 1.
Target folder: H:\Clock\nRF
Source name: H:\Clock\nRF\16F1508_SPI_Test.fcfx
Title:
Description:
Date: Wednesday, June 01, 2016 07:10:22
Users: 1
Registered to: 30day_67332800
Licence key: U5VWEK
C:\Program Files\Flowcode 6\compilers\pic\boostc\boostc_16F.exe -v -t PIC16F1508 "16F1508_SPI_Test.c"
Launching BoostC...
C:\Program Files\Flowcode 6\compilers\pic\boostc\boostc_16F.exe reported error code 1
FINISHED
& the same program compiles OK when software SPI is selected.
San
16F1508_on Software SPI.fcfx
(14.29 KiB) Downloaded 234 times
16F1508_on Channel 1 SPI.fcfx
(14.29 KiB) Downloaded 246 times
LeighM
Post by LeighM »
Looks like an error in Boostc header file
we don't normally edit their files, but here's a quick fix attached
drop in into
Flowcode6..... \compilers\pic\boostc\include
PIC16F1508.h
(69.44 KiB) Downloaded 307 times
Sanjay Singh
I'm getting "error 1" message while compiling the attached program with GPS Macro.
Kindly help.
San
GPS.fcfx
(5.73 KiB) Downloaded 216 times
LeighM
Post by LeighM »
Hi San,
Could you PM your compiler output please? (GPS.msg.txt)
As it works OK on my installation.
Leigh
