I have this feature request that should not be to complicated to implement
but will make Programming with flowcode much easier .
It has to do with Macro Parameters , now I try to explain .
A Macro that can do different Tasks, say if input parameter (Byte)
Is set to 0 will read the external device , if set to 1 it will write , if 2 will configure the device
and so on , now in a macro you can have more then one of these task selectors and it is very
likely that after a few days you forget what the values where doing exactly .
So one have to go through the macro again every time which is very time consuming .
Can we have an option for the parameters that if enabled , will
make it possible to assign a name to a specific value
Something like Html drop down menu . where you have the value and the name to be displayed .
Below is an Example from Labview .
Thanks in Advance
Alan
Macro Parameters
Macro Parameters
- (1.96 KiB) Downloaded 3150 times
- (8.4 KiB) Downloaded 3150 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Macro Parameters
Hi Alan,
One way to implement this now is to use global constants. The attached image and program should help.
- constants as parameters.fcfx
- (5.23 KiB) Downloaded 313 times
- (39.5 KiB) Downloaded 3136 times
hi Steve
yes that is a great idea , although now i realize
that using a variable for every value will increase the
ram usage of the micro controller .
do you think there is a solution to that ?
thanks for your support
- Has thanked: 553 times
- Been thanked: 1081 times
Constants do not use additional controller resources (ram/flash)
― C.S. Lewis
― C.S. Lewis
Hi kersing
Did't know that, so that is a very good work around .
Will implement that for sure .
