Eeprom fails to work correctly
A forums to allow resolved bugs and problems with Flowcode v7 to be stored and marked as resolved.
Zane
Flowcode v5 User
Has thanked: 93 times
Been thanked: 76 times
Post by Zane »
I am using a PIC18F26K80 and the the eeprom fails to work correctly, it works fine in simulation. The program adds some initial values to the eeprom and then tries to read them back and display them. However only zeros are displayed. I have tried this with a PIC16F88 and it works ok.
Flowcode2.fcfx
(7.06 KiB) Downloaded 357 times
Re: Eeprom fails to work correctly
Hi Zane,
Have you applied the fix posted here?
When applying fixes, if flowcode is open then you must select Reload before compiling otherwise the fix just applied won't work.
Zane
Flowcode v5 User
Post by Zane »
Thanks for pointing this fix out, most appreciated.
Cheers
Zane
