have ghost.
But I can not use it
EB006V9
error message : ICD has failed to communicate with the target.
Did not read required Firmware ID size back.
First line is the correct FW ID, second line was read from the chip:
1c 73 f2 1b de 69 e8 1f
ff 00 00 00 00 00 ff ff
Ghost
Whats problem!!
Some Ques. EB006V9
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Some Ques. EB006V9
That usually means that you have not compiled the target code in ICD mode.
Enable ICD mode in Flowcode, then tick the "Enable Icon Step Through" on the Debugger dialog.
Then Compile to Chip.
I completely agree with Leigh on this one.
I would also like to add that if the first and second sets are random hex numbers instead of ff & 00
Then there could be a timing issue probably due to using internal oscillator instead of external.
- Has thanked: 18 times
- Been thanked: 16 times
LeighM wrote:Hi
- LeighM
If you are still having problems, could you attach your Flowcode project file to this thread.
And describe what hardware you have connected to your EB006.
