Just found this I2c bug ( Arduino Mega 2560)
When Communicating with I2c using Hardware Channel 1 with most devices where you have standard protocol structure like
for example DS1307 it works Perfectly .
Init->Start -> Device Address+Write->Target Register-> Restart -> Device Address+Read-> Receive Byte ->Receive Byte->Receive Byte->Stop
So that is fine .
But i have this device that have a slightly different protocol structure to read from it you just transmit the following bytes and it
starts to send data .
Init->Start -> Device Address+Command->Register H-Address-> Register L-Address-> Number of bytes to receive -> RX->RX->RX ..... Stop
The Problem is that with the i2c Hardware Channel it receives the first byte and the MCU stops responding as if it had entered a loop .
also the data received is not correct .
Now when trying whit I2c Software mode all works Fine .
i2C BUG
i2C BUG
- (246.03 KiB) Downloaded 699 times
- (37.29 KiB) Downloaded 699 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: i2C BUG
I've looked into this issue and it looks like this protocol is not supported by the AVR TWI peripheral.
A "Start, SLA+W" puts it into Master Write mode, and a "Restart, SLA+R" is needed to change that into Master Read mode.
I cannot see any way round that, as yet.
So looks like you will need to stick with the Software mode.
Leigh
Leigh
Re: i2C BUG
Hi LeighM
Good to know of this Limitation , The device is Atmel Crypto Memory it's very complicated and I'm not surprised
that it's not compatible .
Thanks for your time .
Alan
Alan
- (29.44 KiB) Downloaded 3654 times
