PIC32 watchdog related compilation error
A forums to allow resolved bugs and problems with Flowcode v7 to be stored and marked as resolved.
pladnows
Has thanked: 6 times
Been thanked: 6 times
Post by pladnows »
another bug report I'm afraid. While attempting to compile a project for a 32MZ2048EFG144 PIC I've noticed a lot of watchdog related errors in the compiler output. The attached example illustrates the problem, a literally empty project fails to compile. Any help would be appreciated. Thanks!
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_Delay.c: In function 'Wdt_Delay_Ms':
C:\Program Files (x86)\Flowcode 7\CAL\internals.c:211:49: error: '_WDTCON_WDTCLRKEY0_MASK' undeclared (first use in this function)
#define MX_CLEAR_WATCHDOG WDTCONSET = _WDTCON_WDTCLRKEY0_MASK
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_Delay.c:108:9: note: in expansion of macro 'MX_CLEAR_WATCHDOG'
MX_CLEAR_WATCHDOG; //Clear Watchdog Timer
C:\Program Files (x86)\Flowcode 7\CAL\internals.c:211:49: note: each undeclared identifier is reported only once for each function it appears in
C:\Program Files (x86)\Flowcode 7\compilers\pic32\bin\xc32-gcc.exe reported error code 255
example.fcfx
(4.48 KiB) Downloaded 482 times
Re: PIC32 watchdog related compilation error
Thanks for letting us know. I have now found and fixed the bug.
To solve the problem simply copy the attached file into your "Flowcode 7/CAL" directory and the project should then compile correctly.
internals.c
(13.27 KiB) Downloaded 495 times
Let me know how you get on.
pladnows
Post by pladnows »
Thanks, that helped. However, there seems to be more. Initializing an ADC_base component results in a following plethora of errors. Below I've added an example that illustrates the issue.
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c: In function 'FC_CAL_ADC_Enable':
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:147:18: error: 'AD1CAL1' undeclared (first use in this function)
_SFR_WRITE(&AD1CAL1,0xB3341210);
C:\Program Files (x86)\Flowcode 7\CAL\internals.c:225:51: note: in definition of macro '_SFR_WRITE'
#define _SFR_WRITE(reg,val) ( *((SFR_TYPE *)(reg)) = (val) )
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:147:18: note: each undeclared identifier is reported only once for each function it appears in
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:148:18: error: 'AD1CAL2' undeclared (first use in this function)
_SFR_WRITE(&AD1CAL2,0x01FFA769);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:149:18: error: 'AD1CAL3' undeclared (first use in this function)
_SFR_WRITE(&AD1CAL3,0x0BBBBBB8);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:150:18: error: 'AD1CAL4' undeclared (first use in this function)
_SFR_WRITE(&AD1CAL4,0x000004AC);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:151:18: error: 'AD1CAL5' undeclared (first use in this function)
_SFR_WRITE(&AD1CAL5,0x02028002);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:153:18: error: 'AD1CON1' undeclared (first use in this function)
_SFR_WRITE(&AD1CON1,0); // No AD1CON1 features are enabled including: Stop-in-Idle, early
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:157:18: error: 'AD1CON2' undeclared (first use in this function)
_SFR_WRITE(&AD1CON2,0); // Boost, Low-power mode off, SAMC set to min, set up the ADC Clock
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:168:18: error: 'AD1CON3' undeclared (first use in this function)
_SFR_WRITE(&AD1CON3,0); // ADINSEL is not configured for this example. VREFSEL of ?0?
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:177:18: error: 'AD1IMOD' undeclared (first use in this function)
_SFR_WRITE(&AD1IMOD,0); // All channels configured for default input and single-ended
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:180:18: error: 'AD1GIRQEN1' undeclared (first use in this function)
_SFR_WRITE(&AD1GIRQEN1,0); // No global interrupts are used.
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:181:18: error: 'AD1GIRQEN2' undeclared (first use in this function)
_SFR_WRITE(&AD1GIRQEN2,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:184:18: error: 'AD1CSS1' undeclared (first use in this function)
_SFR_WRITE(&AD1CSS1,0); // No channel scanning is used.
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:185:18: error: 'AD1CSS2' undeclared (first use in this function)
_SFR_WRITE(&AD1CSS2,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:187:18: error: 'AD1CMPCON1' undeclared (first use in this function)
_SFR_WRITE(&AD1CMPCON1,0); // No digital comparators are used. Setting the AD1CMPCONx
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:188:18: error: 'AD1CMPCON2' undeclared (first use in this function)
_SFR_WRITE(&AD1CMPCON2,0); // register to ?0? ensures that the comparator is disabled. Other
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:189:18: error: 'AD1CMPCON3' undeclared (first use in this function)
_SFR_WRITE(&AD1CMPCON3,0); // registers are ?don?t care?.
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:190:18: error: 'AD1CMPCON4' undeclared (first use in this function)
_SFR_WRITE(&AD1CMPCON4,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:191:18: error: 'AD1CMPCON5' undeclared (first use in this function)
_SFR_WRITE(&AD1CMPCON5,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:192:18: error: 'AD1CMPCON6' undeclared (first use in this function)
_SFR_WRITE(&AD1CMPCON6,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:194:18: error: 'AD1FLTR1' undeclared (first use in this function)
_SFR_WRITE(&AD1FLTR1,0); // No oversampling filters are used.
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:195:18: error: 'AD1FLTR2' undeclared (first use in this function)
_SFR_WRITE(&AD1FLTR2,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:196:18: error: 'AD1FLTR3' undeclared (first use in this function)
_SFR_WRITE(&AD1FLTR3,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:197:18: error: 'AD1FLTR4' undeclared (first use in this function)
_SFR_WRITE(&AD1FLTR4,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:198:18: error: 'AD1FLTR5' undeclared (first use in this function)
_SFR_WRITE(&AD1FLTR5,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:199:18: error: 'AD1FLTR6' undeclared (first use in this function)
_SFR_WRITE(&AD1FLTR6,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:202:18: error: 'AD1TRG1' undeclared (first use in this function)
_SFR_WRITE(&AD1TRG1+(Channel/4),((_SFR_READ(&AD1TRG1)&((0x1F<<((Channel%4)*8))^0xFFFFFFFF))|(1<<((Channel%4)*8)))); // Set AN0 to trigger from software
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c: In function 'FC_CAL_ADC_Sample':
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:216:15: error: 'AD1CON3' undeclared (first use in this function)
_SFR_WRITE(&AD1CON3,((_SFR_READ(&AD1CON3)&0xBFFFFFFF)|0x40000000));
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:219:31: error: 'AD1DSTAT1' undeclared (first use in this function)
while (_SFR_BIT_READ(&AD1DSTAT1,MX_Current_Channel) == 0);
C:\Program Files (x86)\Flowcode 7\CAL\internals.c:227:61: note: in definition of macro '_SFR_BIT_READ'
#define _SFR_BIT_READ(reg,pos) ( ( ( *((SFR_TYPE *)(reg)) )&(1<<(pos)) ) ? 1 : 0 )
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:224:25: error: 'AD1DATA0' undeclared (first use in this function)
iRetVal = _SFR_READ(&AD1DATA0 + MX_Current_Channel);
C:\Program Files (x86)\Flowcode 7\CAL\internals.c:226:51: note: in definition of macro '_SFR_READ'
#define _SFR_READ(reg) ( *((SFR_TYPE *)(reg)) )
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c: In function 'FC_CAL_ADC_Disable':
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:237:15: error: 'AD1TRG1' undeclared (first use in this function)
_SFR_WRITE(&AD1TRG1,0); // Initialize all sources to no trigger.
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:238:18: error: 'AD1TRG2' undeclared (first use in this function)
_SFR_WRITE(&AD1TRG2,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:239:18: error: 'AD1TRG3' undeclared (first use in this function)
_SFR_WRITE(&AD1TRG3,0);
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:240:15: error: 'AD1CSS1' undeclared (first use in this function)
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:241:15: error: 'AD1CSS2' undeclared (first use in this function)
C:\Program Files (x86)\Flowcode 7\CAL\PIC32BIT\PIC32BIT_CAL_ADC.c:242:19: error: 'AD1CON1' undeclared (first use in this function)
_SFR_BIT_CLEAR(&AD1CON1,15);
C:\Program Files (x86)\Flowcode 7\CAL\internals.c:229:57: note: in definition of macro '_SFR_BIT_CLEAR'
#define _SFR_BIT_CLEAR(reg,pos) ( *((SFR_TYPE *)((reg)+(1))) = 1<<(pos) )
example_2.fcfx
(5.37 KiB) Downloaded 464 times
It looks like this is going to take more time to solve, the ADC on this device looks very different to the other MZ ADC devices which explains the compilation errors being generated.
Hopefully I'll have a fix for you soon.
pladnows
Post by pladnows »
Looking forward to that, thank you.
Right this is now compiling correctly. I don't currently have one of these devices to hand to actually test if the code works so please let me know how you get on.
Firstly you have to copy this file to your "Flowcode 7/CAL/PIC32BIT" folder.
PIC32BIT_CAL_ADC.c
(14.83 KiB) Downloaded 474 times
Next you have to copy this file to your "Flowcode 7/FCD/PIC32" folder.
32MZ2048EFG144.fcdx
(61.1 KiB) Downloaded 458 times
Then restart Flowcode and the code for the ADC should now compile correctly.
Brendan
Has thanked: 140 times
Been thanked: 118 times
Post by Brendan »
Hi Ben.
Many thanks for the timely fix, and happy to confirm that the project now compiles without error :D
Best regards,
Brendan
pladnows
Post by pladnows »
Thanks Benj, your help is greatly appreciated.
