Strange Behavior
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
Alan_37
Has thanked: 51 times
Been thanked: 54 times
Strange Behavior
Post by Alan_37 »
I have been developing this Fat ( Miro-SD ) read and Execute from File stored on
Micro sd , but at point I got stuck in this Problem which I think is a Bug .
When I try to read and exec commands only the first 1 will run , After
doing some investigation I found that the problem is in the String manipulation
maco -> Global_Str = Left$ (RS232_OUT,7) this works fine the first time it executes
but After that Global_Str will Have only the first 5 letters not 7 .
When Checking Global_Str length it display’s 7 although string was sent via rs232 and I can only see
The first 5 letters only .
I was Not able replicate this in a new file , happens only in my project so I have included the FCFX file .
Fast Dev.fcfx
(56.81 KiB) Downloaded 261 times
test.txt
SD Card File
(39 Bytes) Downloaded 289 times
Rs232 Debug Output
(22.18 KiB) Downloaded 2295 times
Alan_37
Re: Strange Behavior
Post by Alan_37 »
Hi Here is an update
After spending several hours trying to find what is wrong , I found a more Advanced Serial monitor
And now I can see that the output string really contains 7 characters, the 2 characters
at the beginning of the string are causing the problem 0d 0a , please see attached Pic
According to the ASCII Table 0d is carriage return , and 0a is line feed ok
these are in the txt file, but I thought they should be at the end of the string not at the beginning .
Now not sure if this is a bug or not , I will try to resolve by scanning the string and remove
these characters before running the string manipulation
I beleve that thes 2 characters are comming from the end of the previous line and there is where they should
Be at the end of the string.
(15.44 KiB) Downloaded 2244 times
(22.61 KiB) Downloaded 2244 times
Alan_37
Post by Alan_37 »
I have worked around this problem , Please Delete / Move this tread if you feel this
is not a bug .
Thanks .
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
OK, thanks for the update.
As you have found, the ReadStringFromFile captures all characters from the file until the specified EndChar matches, in your case this is the ';' character.
At this point it will stop.
So the next read will include the CR/LF pair that occur after the ';'
You could at that point do another read with EndChar set to 0x0a to flush the CR/LF pair.
