how to get a glcd work with with PIC16F1937
Nasim Khaliqhey
- Has thanked: 1 time
- Been thanked: 3 times
dear advioser
I have finished my project of driving a motor & Displaying the information in a EMB001 it works in my laptop ok
but when it installed in pcb with what I have the equivalent gLCD (1.44´SPI 128* 128 V1.1
it dosem´t show nor it starts the display
the crystal for clock pules is a 20 Mhz
the configurations are as flowed
Zox8007
Oscillator HS oscillator speed crystal, 20Mhz
Watchdog Disable
power up timer //////
MCLR Enabled
code protect off
data EE read protect Disabled
Brown out Reset Enable
Clock out Enable Disable
Internal-External switch over Disable
Fall clock Monotor Enable //////
Zox 8009
Flash memory write protiction Disable
voltage regulator capacitor //////
Pll Enable bit //////
Stack overflow/underflow Reset Enabled
Brown-out reset voltage Brown out Reset voltage (VBO)
Debuggur Mode Disabled
Low voltage programming Enable bit Disabled
there must be a mistake can you kindly tell me which one is that?
Zox8007
Watchdog Disable
MCLR Enabled
code protect off
Zox 8009
Re: how to get a glcd work with with PIC16F1937
Have you tried the 1 second flasher approach to test if the micro is running at the right rate.
http://www.flowcode.co.uk/wikiv7/index.p ... ED_flasher
You can also attach your program using the upload attachment tab underneath the "Post A reply" window when replying.
Nasim Khaliqhey
dear Leigh M
Thanks allot for you use full advice
but it is the same can you kindly look at the attached configurations there must be some mistakes here I can not send the all document snap shots more then 3 please advice me which ones to choose
with regards
Nasim
with regards
Nasim
- (90.16 KiB) Downloaded 1927 times
- (94.45 KiB) Downloaded 1927 times
- (85.81 KiB) Downloaded 1927 times
HI nasim
Config looks ok but i always enable power up timer, from your posts, the program works ok and displays ok when connected to your laptop, so i am assuming that you are programming chip which works fine in your test setup, but when placed in final pcb with a different display it doesnt work, is this correct ??
If so please attach your flowchart so it can be checked over and also provide a link to the lcd you are using in your own pcb, as to be fair if it works with the ebm001 and not in your board there may be an issue with the lcd you are using. it would also help if you attach your flowchart to any post asking for help as it allows people to see if theres a code issue
dazz
dazz
Nasim Khaliqhey
Dear adviser
thanks for you information sorry I am late but I am sending you a copy of my software work
see if you can find a way to make it work with the mentioned display
with regards
Nasim
with regards
Nasim
- New micro control A1.fcfx
- no data show on display
- (24.51 KiB) Downloaded 700 times
Hello Nasim,
Secondly you say EBM001 equivalent. The EBM001 component will ONLY work with the EBM001 display module and other display modules with the exact same driver IC onboard.
Where did you purchase your display, do you have a link or a datasheet?
First of all I would take the EBM001 Initialise component macro out of the loop and place this before the start of the loop.I have finished my project of driving a motor & Displaying the information in a EMB001 it works in my laptop ok
Nasim Khaliqhey
pic16F1937 interrupt weirdness Timer0 in simulation
Dear Benj
thanks for your last information of placing the initalising gLCD be for the Loop that is making the action of display faster in my laptop but still
I could n`t get the data display in my EBM001
here I attach some of my work
the Bread board I made are supplying the right voltages & current to the pins according to the PIC16F1937 & EBM001 Datasheets
please take a look of these point when you have time for ,
The graphs are showing the data out put pin of PIC ,B0 & data input of EBM001 both the same according to the time base of my scope
Looking forward hearing from you
with regards
Nasim
with regards
Nasim
Hi Nasim,
I have moved your post from 'pic16F1937 interrupt weirdness Timer0 in simulation' topic as your post has nothing to do with that subject.
Please try not to hijack other users topics.
Hello Nasim,
Please can you draw up a basic schematic of your microcontroller, the oscillator circuit and the EBM001. It sounds to me like your chip isn't running on your hardware.
You can confirm this by following the information here to do a 1 second flash test.
Your scope traces seem to be showing mains hum so that seems to confirm the chip is not running.
If you draw up the schematic then we can hopefully help to pinpoint why the chip is not running. A photo of your breadboard may also help but a schematic is easier to read.
Another thing I have noticed is that all the switches in your program are Simulation switches. E.g. switches that have no pin connection and are available in the Flowcode simulation only. Is this correct?
Nasim Khaliqhey
thanks
I will take a small photos of my drawings and send to you .
as we all know it is Christmas month we are all busy
but I hope to get some where to success this project.
thanks again
wr
Nasim
thanks again
wr
Nasim
Nasim Khaliqhey
hey Ben J
can you please have a look at my work notes to find my mistakes ?
Connection notes:
1-MLCR connected to 4v9 via 10 k resistor & a switch for reset
2-A0 has been tried by inserting 3v3 or 4v9
3-A4 is connected to Clock pin 13
4-I used a Zenor Diode of 5v1 with 10R resistor for pic safty.
5-Crystals I hav tried are : 32MHz,20MHz AND 8MHz
6- I don´t know about basic_sim_switch I couldn´t find any other LED´s to set for representing the rotating switch number
there for I used the basic_sim_switch.
With regards
Nasim
Connection notes:
With regards
Nasim
- (499.31 KiB) Downloaded 1436 times
- (914.41 KiB) Downloaded 1436 times
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Are you sure your 8MHz clock crystal really uses 0.1nF = 100p load caps (according the schematic and picture)? Usually 10-35pF ceramic is enough.. I personally use max 22pF load caps for my crystal oscillators.
Edit: are both pins connected from xtal to the micro? Cant see any line going from the left side to anywhere else than to load cap on the schematic...?
Nasim Khaliqhey
dear adviser
yes always two 0.1nf dc blacker been set between the two pins of crystal & Grd (-)
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
That is incorrect as Estdriver mentioned it should be between 10-35pF did you try to flash a led to make sure your mcu is running ?Nasim Khaliqhey wrote: yes always two 0.1nf
Regards QMESAR
Regards QMESAR
EtsDriver
Here is a drawing of how i usually connect the xtal, for example on 16F1937, note the cap values:
Nasim Khaliqhey
Re: how to get a glcd work with with PIC16f877A
hi Ben
there has been allots of mistakes in my communications
sorry to repeat
I tried to send by( L in) but it was not possible to sent the right document I can not find the right programming configuration for PIC´s I am using even I tried at micro soft`s
info page I just see the same question been asked by many people
If you have any document for solving this problem please send it to me if not just forget about it and kindly let me know when do you have the program of course for this solution I will be pleased to book & fix the time for it.
looking forward Hearing from you
with regards
Nasim
sorry to repeat
with regards
Nasim
- New micro control A1.c
- (39.46 KiB) Downloaded 499 times
Hi Nasim,
What problem are you experiencing? can you elaborate?If you have any document for solving this problem
Nasim Khaliqhey
Sorry the unfinished project was sent by mistake I all ways start my out side work at 1 PM there for I must have been in a rash
but the result has been the same no mater what Display or PIC been used
every thing shows ok in my lap top but no action when data sent to PIC.
thanks allot
with regards
Nasim
thanks allot
with regards
Nasim
- PIC16F877A F7.fcfx
- (7.33 KiB) Downloaded 476 times
EtsDriver
Did you edit your circuit according to the diagram i posted above? What are your current load capacitors for your PIC?
Just to notify, your program has many "If 1":s... That might cause unexpected behavior...
Nasim Khaliqhey
Hey Dear
hear I tried the way I was asked for with deference crystal oscillator 20 ,16, 8, and 4 MHz , not RC,
the result is the same.
by the way this is what I thing about that my programmer PPPV3 some how dose n´t have a good drive software us I mentioned some times ago
example dose not have in it is list PIC16F1937,
please see this matter don´t need to rash see when you have a good time
looking forward hearing from you
wr
Nasim
wr
Nasim
- PIC16F877A F7 for begianing.fcfx
- (5.94 KiB) Downloaded 465 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
You could try the newer mLoader? ...my programmer PPPV3 some how dose n´t have a good drive software
http://www.flowcode.co.uk/old_site/resources/getr ... php?id=884
Nasim Khaliqhey
hey dear Leigh M
thanks for your help it shows a little deference in sending data to the chip
can you please give me these configurations with PIC16F877A ,3 kinds of out puts
gLCD ,16X2 line LCD ,and LEDS wich Ones of these options will be Enable or Disable with choice of Oscillators
1-Oscilltor ?
2-Watchdog Timer ?
3-power up Timer ?
4-Brown out Detect ?
5-Low voltage program ?
6-Flash program write ?
7-Back ground Debug ?
8-Data Read protect ?
9-Code protect ?
may be this will help me to get the programmed data displayed
(Note Each one of displays plans are with one PIC separate from each other ) not to be confused just to know the settings ,
with regards
Nasim
sorry if I am late always my Fridays are same thing takes my all day.
1-Oscilltor ?
2-Watchdog Timer ?
3-power up Timer ?
9-Code protect ?
with regards
Nasim
Nasim Khaliqhey
hey dear Leigh M
as I mentioned the display problem with using pic16F877A or pic16f1937 with display EBM001
Now I used my Data man programmer to be able to inter PIC16F1937 becuase my programmer EB-006-00-8 dose not have the 16F1937 in it is component list
I am sorry it is a complicated problem .
I have time to come to England in 08 2017 to find out what is missing in processing this project if you can find half an hour to spend with me I´ll be pleased
with regards
Nasim
Note: I attached 2 copies data configurations but can not be seen why ?
with regards
Nasim
- LeighM
These are the default settings when you create a new PIC16F877A project,
the settings are the same whatever you connect (LCD, gLCD, LEDs),
but the Oscillator setting is important and depends on your hardware,
this setting assumes that you have an external (19660800Hz) crystal for the oscillator ...
Nasim Khaliqhey
hey Mr LeighM
lets say Thank you I needed this advice to begain with my very first project the programmed PIC has started to work now
I will let you know about the rest lets say again I owe you thanks
with regard
Nasim
with regard
Nasim
