Hi guys,
When starting up my Flowcode 6 program today, I was informed that a newer version was available for download. I downloaded the patch (Ver 6.1.4.0) and tried to run it to upgrade my software. I am currently running Version 6.1.3.2 on my computer.
When trying to upgrade my software to the newer version it tells me: "This patch is for Version 6.1.3.2 only. Patch tool will now exit" now I'm lost as according to this patch my old version is the correct one to upgrade!
Can someone please tell me how to run this upgrade?
Thank you
Ted
New patch 6.1.4.0 for Flowcode 6
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: New patch 6.1.4.0 for Flowcode 6
If you are having problems you can get the full installer from here:
http://www.matrixtsl.com/accounts/files ... .1.4.0.msi
Then simply uninstall and reinstall Flowcode. There arent really any key fixes in here unless you are using Ghost.
Hi All,
For those of you that have difficulties installing the new patch 6.1.4.0 where it tells you that it is a patch only meant for 6.1.3.2 upgrade, rerun the previous patch 6.1.2.0 to 6.1.3.2 supplied some time ago as the Flowcode V6 program tells you that it has upgraded and is version 6.1.3.2 but in fact by checking the "logs" file in Flowcode directory I noticed that the program was still registering 6.1.2.0!!
Now run the 6.1.4.0 patch and all is sorted.
Thanks David for your help.
Ted
Ted
- Has thanked: 1135 times
- Been thanked: 299 times
Hi!
The new update, is this also included all the fixes for bugs since last update, please?
Br.
Jorgen
Br.
Jorgen
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
This patch is just a Flowcode executable patch for a Ghost ICD issue.
Note that the components and CAL are as the previous release, so unfortunately will overwrite any updates that a user has downloaded from the forum.
So please make a backup of these before running the patch.
