I have developed a battery-powered clock that periodically synchronises with the MSF transmitter at Anthorn. So far, I have not had to resort to the use of C and I enjoy FlowCode's clarity compared with my previous failed C attempt for this project.
I now have to refine the code to provide an acceptable battery life, and I need to be able to do the following (at least):
1) configure the PIC for minimum power consumption
2) enable weak pull-ups for portB, bits 4-7 (for a button interface) and disable them again during sleep
3) switch between a 4MHz clock rate (or greater) oscillator for the duration of time lock-on and update and a 32kHz external clock for timekeeping
All of these, so far as I can see, require the use of the C icon.
Is there any guidance on the coding to be used with the XC8 compiler please?
I have tried to interpret the XC8 compiler User Guide, which suggests (to me!) the use of the #pragma, but this gives a compile error, e.g.,
1217: #pragma INTSRC = 0;
^ (335) unknown pragma "INTSRC" (warning)
using the seemingly deprecated __config() statement gives
1221: __config ("WPUB", 0b11110000);
^ (195) expression syntax
Using just __WPUB = 0b11110000; I get
1159: __WPUB = 0b11110000;
^ (192) undefined identifier "__WPUB"
Using #pragma __WPUB = 0b11110000;, I get
1159: #pragma __WPUB = 0b11110000;
^ (335) unknown pragma "__WPUB" (warning)
By trial and error, I have found that, for example,
INTSRC = 0;
does work; Is this the general rule, i.e.,
a) Use the MPLab data sheet for your pic
b) Find the register definitions for the purpose in hand
c) Refer to the bit or group of bits by the data sheet name and set the value
This seems to work some of the time, e.g., PLLEN = 1 quadruples LED blink rate in a timer loop, but others such as
WPUB 0b11110000; does not change the voltages on portB(4..7), either measured on the pin or sampled using an input icon with the port open circuit; nor does it light any leds on an EB004 board (WPUB4 = 1; does not work either).
I am clearly missing something here, and will feel foolish when I hear the answer. Can you point me at where I should look for this please? Coming back here for each item is likely to prove tedious for all of us!
* I am using the PIC 18F45K22, EB006 with a PIC-KIT3 programmer (Olimex) *
Jim
Controlling PIC registers using XC8 C
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Controlling PIC registers using XC8 C
I am not sure if I understood your problem correctly and apologize if I did understood it incorrectly
any case a few point from my side
During Run time you need to access the register directly as per data sheet as you also have seen it does work
Flowcode support everything that is supported in the XC8 as the C code generated when you press compile is exactly as any one would write it from hand for the XC8 compilers.However the syntax you are using with your #pragmas is incorrect I would advice you to go to MPLABx open a project for your device and then go to windows >> PIC Memory Views >> Configuration bits then select the configuration bits as you would like them to be and press Generate code then look at the generated code and you will see how the Pragma syntax looks with this said you can not use the #pragma directives on the fly meaning while your controller is running (run time ) you can not do #pragmas to change configuration this is only allowed during startup as far as I know and tried in the pastI have tried to interpret the XC8 compiler User Guide, which suggests (to me!) the use of the #pragma, but this gives a compile error, e.g.,
Regards QMESAR
Regards QMESAR
Hi Jim,
With weak pull-ups on a several microcontrollers you also need to clear bit 7 of OPTION_REG.
Have you seen this post?
Hi, Martin
I installed the MPLAB X IDE and that gives instant feedback if the registers are not recognised. As QMESAR suggested just using the register name in upper case does the job.
Yes you are right, for the 18F45K22, it is necessary to use
WPUB = 0b11110000; // weak pull-ups on PORTB.4-7
RBPU = 0; // Switch on pull-ups
as well as to set the port as an output.
It all seems to work fine now, there are many things to switch off! Many thanks
Jim
Jim
