After applying the latest patch for Flowcode 7 the project will not compile to hex any more
the problem is in the Servo_Controller.fcpx , reverting to the old file fixes the problem but stuck with
the old version .
I am using Arduino 2560 R3 .
After applying Patch 7.1.1
- (24.25 KiB) Downloaded 2644 times
- (26.02 KiB) Downloaded 2644 times
Re: After applying Patch 7.1.1
Many thanks for letting us know.
This component should fix the problem. Simply copy the file into your "Flowcode 7/components" directory and this should solve the issue.
Let us know how you get on.
Hi Benj
Yes That Fixed the Servo Problem 100% thanks .
Now just found another problem related to the patch but this time i didn't had the time
to investigate , the only thing i know is that it stops executing commands from SD Card after
about 10 commands or so replacing FAT.fcpx with the old file Fixes the problem 100%
Hope you can find the problem .
Hello Alan,
That's brilliant thanks for letting us know.
Please can you try the new FAT component here and see if this fixes the problems you're having.
http://www.flowcode.co.uk/mmforums/viewt ... 356#p78721
Many thanks.
Many thanks.
Hi Benj,
Yes the file from that post Fixes the SD Card Problem 100%.
Please update the patch with these files .
Thanks very much for your fast support
