Inline assembly in FC7
Andreas
Has thanked: 4 times
Been thanked: 1 time
Post by Andreas »
I have until now been using FC5, and therefore have a lot of old programs programs, which is programmed in FC5. Unfortunately i do no longer have access to my former FC5 licens, and i am now started to use FC7, starting with the 30 days trial.
In some of my programs i have inline assembly code, but this code made in FC5 seems to create a lot of troubles in FC7.
The code would look something like this:
asm{
send1:   BSF  _porta, 0
         NOP
         NOP
         NOP
         BCF _porta, 0
slut1:   END
During compiling, something like the following error appeared
"(" expected
string expected
")" expected
I found out that a solution on the error could be found by changing the code to
asm(
"send1:   BSF  _porta, 0"
         "NOP"
         "NOP"
         "NOP"
         "BCF _porta, 0"
"slut1:   END"
But this just caused another error saying
syntax error
Undefined symbol "0NOPNOPNOPNOPBCF"
And in the generated assembly-code, everything in the assembly-block seems to be squeezed together on 1 single line like:
send1: BSF _porta, 0NOPNOPNOPNOPBCF _porta, 0slut1: END ;#
I hope someone here can tell me what is happening and how to use inline assembly in FC7
Andreas
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: Inline assembly in FC7
Post by LeighM »
try this...
asm(
"send1:   BSF  PORTA, 0\n"
         "NOP\n"
         "NOP\n"
         "NOP\n"
         "BCF PORTA, 0\n"
Andreas
Post by Andreas »
Thanks for the answer.
I read the manual for mplab XC8 compiler and found out that using #asm and #endasm was solving my problem. Unfortunately this lead to other syntax-errors, but i found a workaround and now everything works fine.
