When running in ICD mode, adding variables to simulation debugger watch window is very hit and miss for me.
ICD & Adding Variables to Simulation Window
Re: ICD & Adding Variables to Simulation Window
Hi Martin, please can you elaborate a bit on what you mean by it being hit and miss? What exactly is the problem?
If you have time please can you post an example project that you are having problems with and a list of steps to replicate the issue?
Simon
Simon
Hi Simon,
With any flowchart that has not yet got variables added to the watch window of debugger.
Running ICD in single step mode:
When hover over below expression word the red arrow just flashes as the cursor moves.
As soon as cursor is still, the red down-arrow disappears: When not in ICD mode, red down arrow is solid when cursor is hovered below expression word: Martin
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Hi Agree with Martin this is also happening with me and in addition to that once the ICD is running. I can not pause the ICD (with the pause button) the only way I can stop the ICD is by pressing step into, then the ICD will stop in the next function or place in flowchart it was suppose to execute.The pause RUN and Stepping functions is not working as intended
The pause button change it color when placing the mouse cursor over it and by pressing it seems to activate a press but with no effect
Regards QMESAR
Regards QMESAR
I can see the problem also on my machine but unfortunately 7.2.1 was release on Friday
it should fix the problem of being unable to pause ICD though.
Simon
Simon
- QMESAR
SimonB wrote:Hi,
I can see the problem also on my machine but unfortunately 7.2.1 was release on Fridayit should fix the problem of being unable to pause ICD though.
Simon
For what it worth Simon The issue is not fixed with me in 7.2.1
Regards QMESAR
Regards QMESAR
