(Version 6.1.3.2)
My application has an emergency STOP button and I need the program to abort upon pressing of that button.
I have INT0 on the chip assigned to the STOP button and a small interrupt routine associated with it.
To avoid having to test an interrupt status flag in many places throughout the program I was hoping to use a Connect to jump to the END label, but apparently the scope of Connect is local as I cannot see the associated connection point label in Main from within the interrupt routine.
Note: at this stage of development the need for a program abort/halt is within simulation mode so that I can demonstrate the prototype.
How do I simulate an abort/halt?
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: How do I simulate an abort/halt?
The code at the end of your program is just an infinite loop, if all you want to do is to permanently (until reset/power cycle) halt execution of you code you can just insert a never ending loop (loop with condition always true) in your interrupt routine.
― C.S. Lewis
― C.S. Lewis
