arduino Code files
achillis1
Has thanked: 91 times
Been thanked: 8 times
arduino Code files
Post by achillis1 »
As I understand Arduino uses it's own programming language. So when I compile to chip within Flowcode ; is there a directory in which I can find this arduino code?
Thank you
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: arduino Code files
Post by LeighM »
Flowcode creates a C source file, in the same directory as the Flowcode .fcfx file.
This C file is compiled, together with Flowcode CAL C files, to product object code for the target AVR device.
The programming step flashes the code to Arduino compatible target boards using their on-board Ardunio bootloader.
The Flowcode generated C files are not "Arduino code".
The Ardunio IDE Sketches are C++ and also make reference to Arduino library code, Flowcode does not.
Hope that helps,
Leigh
achillis1
Post by achillis1 »
Hello Leigh,
So you mean that flowcode does not have to transleta C into Arduino language? The Arduino can understand C?
Thank you
LeighM
Post by LeighM »
What do you mean by "Arduino"?
Arduino is not a language.
C and C++ are languages that are compiled into binary code that runs on the processor devices that Arduino and compatible products use (mainly AVR)
Does that help?
achillis1
Post by achillis1 »
Yes Leigh, it helps! Thank you.. :)
