Internal and external CAN-BUS interfaces
Barmaley_GMN
Has thanked: 8 times
Been thanked: 4 times
Post by Barmaley_GMN »
When I try to use both (internal and external) CAN interfaces, compilator stops with a lot of errors.
How can I solve this problem?
Yat122222.fcf
(23.36 KiB) Downloaded 207 times
Re: Internal and external CAN-BUS interfaces
This kind of thing should work in v6 or v7 which is designed to havce multiple instances of the same component. However in v5 there is likely to be conflicts as the CAN bus component is only designed to be used in a program once. You may be able to use the custom code fetaure to edit the conflicting names in the second CAN component.
As v5 is now very out of date, out of support and the problem should already be resolved in v6 and v7 it's unfortunatley not likely something we can fix for you.
Barmaley_GMN
Clear!
Thanks!
