Subtract a number of the EEPROM
electron67
Has thanked: 106 times
Been thanked: 48 times
Post by electron67 »
Hello, Merry Christmas for all and have a good year 2018 !!! :D
Could someone help me, what is wrong with the program; I'm taking Martin's program to record numbers from 1 to 900 in the EEPROM of the pic, I think is simple, but I have something wrong, first I have a delay of 2 minutes to turn on A2, then a timer keeps counting to 900 , I think that by disconnecting the pic from the power source, the number found in the timer will be recorded in the EEPROM, when reconnecting the pic, the EEPROM will be read and subtract 2, and when the count reaches that value go off A2.
Enrique
RET887.fcf
Flowchart
(28.52 KiB) Downloaded 233 times
Re: Subtract a number of the EEPROM
Hi Enrique,
Thank you & merry Christmas to you too.
You first need a routine to check when power source as been removed.
This post may be of some help?
electron67
Hi Martin
Thank You very much for the answer, with the diode and capacitor works as a small battery.
Enrique
