i wonna use a 16f877a for controling a electric gate.
i have made a program with flowcode.
Its working fine i a simulation but whe i program the pic and test it, the pic isnt doiing the right things.
When i use only the first part of the program its ok, with the secund part it stop working.
Is there a max of decisions you can make with flowcode?
i placed the prog i a attachtment.
Can someone give me some tips how i can solf the problem?
Many thanks
Filip.ledoux@telenet.be
problem with 16f877a
- Has thanked: 6 times
- Been thanked: 44 times
Re: problem with 16f877a
Hello Filip,
I have tested your program (as far as I understand it) and it seems to work correctly. I removed the unused components (alarm, internet, etc).
Could you send me the details of your Flowcode installation: version number, installation type (professional, student etc). This information is available from the Help->About Flowcode... menu.
Thanks for your time but i solved the problem self.
I mis wired the pic on my design board.
greetings Filip
greetings Filip
