Communication RX TX pins
Please add any feature requests for Flowcode version 7 here
With RS232, HC05/06 etc can an option to disable RX or TX be implemented.
For example I'm using 12F1840 and using RX only.
If we can select disable TX then that would free an additional pin.
I have had to do that manually with a Ccode block with
clear_bit(TXSTA,5);
Would be nice if automated.
Re: Communication RX TX pins
Thanks Martin,
I'm having a quick go to see if I can build this into the v8 UART CAL then we can expose it in any components that would suit the option to disable RX or TX.
Also going in is the ability to easily switch the CAL component on or off. This should make multi CAL components much easier to build for example modules that support multiple interfaces - I2C/SPI/UART.
Looking further in to this today.
I'm not sure if its even possible?
With
clear_bit(TXSTA,5);
the TX is disabled and the o/p drops to 0.
So I would assume output will now work?
Wrong.
Looks like with
SPEN = 1
there is no i/p or o/p control.
With
SPEN = 0
i/p & o/p is given control but RX will stop working.
Any idea on how to just use RX and allow the TX to be a controllable i/p or o/p?
Left in features as if it can't be done then this feature request is not possible.
Hmm I would have thought just clearing the TXEN bit would have done it but if this isn't working then it may be as you say that both pins are always used even if they are not enabled. I've put this code in v8 but not given it a good test yet so I'll try and get onto this for you and see what's possible.
Thanks Ben,
I appreciate that.
