So V8 has been released!
I have to ask are there any help files included (me thinks I know the answer)?
Help Files
Re: Help Files
There is Wiki V8 help
Also If you add a component to a panel, you can right click on it then select Help just like you could in other versions of Flowcode.
There are also Blogs posted to help.
E.g: http://www.matrixtsl.com/blog/flowcode- ... seudocode/
http://www.matrixtsl.com/blog/flowcode- ... ocks-mode/
http://www.matrixtsl.com/blog/flowcode- ... ng-c-code/
Re: Help Files
So following your link, again Matrix have chosen to make 'statements' about their software other than having a proper help system for each and every command which we then can use and learn from.
Matt
Matt
Re: Help Files
Hi Matt,
Is there anything specific you're after, it maybe we have already documented it on the wiki and it maybe not the easiest to find, or if not already there then we can put some effort into making sure it's there and easy to find.Matrix have chosen to make 'statements' about their software other than having a proper help system for each and every command which we then can use and learn from.
