Usb wont compile. [SOLVED]
Roy Johnston
Flowcode V4 User
Has thanked: 2 times
Been thanked: 34 times
Post by Roy Johnston »
Target folder: D:\Smokehouse Development\Screen_tester\Flowcode
Source name:   D:\Smokehouse Development\Screen_tester\Flowcode\screen6.fcfx
Title:
Description:
Device:        PIC.18F.18F4550
Generated by:  Flowcode v8.0.0.6
Date:          Sunday, May 27, 2018 08:26:15
Users:         1
Registered to: Roy Johnston
License key: 00Z8M5
http://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat  18F4550 "D:\Smokehouse Development\Screen_tester\Flowcode\" "screen6"
D:\Smokehouse Development\Screen_tester\Flowcode>C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=18F4550  "screen6.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
Employing 18F4550 errata work-arounds:
 * Corrupted fast interrupt shadow registers
USB_CONFIG: 155: (141) can't open include file "../../../CAL/PIC/USB/usb_generic_config.h": No such file or directory
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
screen6.fcfx
(12.01 KiB) Downloaded 265 times
Reason: Use code tags for easier readablity when posting compiler logs
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Usb wont compile.
Post by QMESAR »
Hi Team.
I confirm this as well ,my USB slave MIAC project compiling and running on a MIAC also does not compile in V8 with the same error report as Ray above :D
Thanks for letting us know, I can see what is causing the problem and it should be a fairly easy fix.
I'll let you know as soon as I have rolled out a fix.
I've now pushed a change to the updates system which should solve the problem for you.
Here are some instructions on how to use the updates system.
https://www.matrixtsl.com/wiki/index.ph ... ic_Updates
QMESAR
Post by QMESAR »
Thank you very much just compiled successfully :D ,
I appreciate the quick fix
Roy Johnston
Flowcode V4 User
Thank yoy _ solved
