Problem PIC16EP512GU810 con V8
MOCUELSL
Has thanked: 8 times
Been thanked: 5 times
Post by MOCUELSL »
Good morning Benj, when updating to the V8 version of the flowcode, I compile the program that I enclose with the pic16Ep512Gu810 and it gives me error 1; with the previous version of flowcode I did not give any error; You can tell me what is due. Thank you.
medidor 24EP512GU810.fcfx
(206.13 KiB) Downloaded 217 times
Re: Problem PIC16EP512GU810 con V8
Please can you check the pin connections for the SPI Master component. This component has been upgraded and so the pin connections from v7 to v8 may be lost.
Everything else looks like it should be ok to me.
MOCUELSL
Post by MOCUELSL »
I have verified what he has told me and I have effectively changed the pins and it is already working. Thank you very much for your help.
