PROBLEMS WHEN COMPILING RTC
Foro para hablantes de español que deseen escribir en su lengua materna.
MOCUELSL
Has thanked: 8 times
Been thanked: 5 times
Post by MOCUELSL »
Good morning Benj, I'm working with professional V8 flowcode, I want to use the RTC component with my Pic24FJ1024GB610 chip in my project, but when compiling I always get error 1 and I do not know what may be due; I am enclosing the file so you can tell me if it is a chip or programming error. Thanks in advance
PANTALLA TFT ILI9341 - RTCC.fcfx
(12.06 KiB) Downloaded 573 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: PROBLEMS WHEN COMPILING RTC
Post by LeighM »
Could you try with the attached updated files.
C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\PIC16\24FJ1024GB610.fcdx
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC16BIT\PIC16BIT_CAL_RTC.c
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC16BIT\PIC16BIT_CAL_I2C.c
PIC16BIT_CAL_I2C.c
(27.91 KiB) Downloaded 549 times
PIC16BIT_CAL_RTC.c
(9.34 KiB) Downloaded 606 times
24FJ1024GB610.fcdx
(47.99 KiB) Downloaded 515 times
MOCUELSL
Post by MOCUELSL »
Good morning Benj, thank you very much for your solution, it compiles perfectly, now I have a problem and I ask the PTC18FJ1024GB610 internal RTC clock for hours, minutes and seconds, send them to me at high speed, I have tried all the possible combinations of the fuses but I have not been able to find out the problem. I attached the file to see if you can help me. Thank you.
(13.61 KiB) Downloaded 534 times
MOCUELSL
Post by MOCUELSL »
good morning Benj, we are using an oscillator of 32,768khz, we believe that the value of the RTCCON2H register does not have the appropriate value for this oscillator.
rtcc.pdf
(108.98 KiB) Downloaded 566 times
MOCUELSL
Post by MOCUELSL »
GOOD AFTERNOON BENJ, THERE IS ANY WAY TO BE ABLE TO CHANGE THE VALUE OF THE VARIABLE (MX_RTC_DIVIDER) OF THE COMPONENT Internal RTC.
You can either edit this line of the PIC16BIT_CAL_RTC file.
RTCCON2Lbits.PS = MX_RTC_PRESCALER;		//Set the RTCC Prescaler
to something like this, changing the 1 to the value you require.
RTCCON2Lbits.PS = 1;		//Set the RTCC Prescaler
Or you can call the initialise function as is leaving the CAL file untouched and then change the register value yourself using the following code in a C code icon.
		RTCCON1Lbits.RTCEN = 0;					//Disable RTCC
		//Enable RTCC Register Writes.
		asm volatile ("DISI #6");
		asm volatile ("MOV #NVMKEY, W1");
		asm volatile ("MOV #0x55, W2");
		asm volatile ("MOV W2, [W1]");
		asm volatile ("MOV #0xAA, W3");
		asm volatile ("MOV W3, [W1]");
		//asm volatile ("BCLR RTCCON1L, #WRLOCK");
		RTCCON1Lbits.WRLOCK = 0;
		asm volatile ("nop");
		RTCCON1Lbits.RTCEN = 1;					//Enable RTCC
Either way let us know how you get on.
MOCUELSL
Post by MOCUELSL »
IT DOES NOT WORK WHAT I WANT TO DO IS CHANGE THE VALUE OF THE RECORD, (RTCCON2Hbits.DIV = 3FFF;) TO USE A 32,768khz OSCILLATOR IN A PIC 24FJ1024GB610
REGARDS
MOCUELSL
Post by MOCUELSL »
FORGIVES
RTCCON2Hbits.DIV = 0x3FFF;
MOCUELSL
Post by MOCUELSL »
[img]Topic%20review[/img]
MOCUELSL
Post by MOCUELSL »
(84.62 KiB) Downloaded 3688 times
MOCUELSL
Post by MOCUELSL »
(239.12 KiB) Downloaded 3688 times
MOCUELSL
Post by MOCUELSL »
con este código el RTCC funciona a su velocidad pero hay un error en la variable que mide los minutos, los mide como si segundos.
RTCCON2Lbits.CLKSEL = 0;
RTCCON2Lbits.PS = 0;
RTCCON2Lbits.FDIV = 0;
RTCCON2H = 0x3fff;
MOCUELSL
Post by MOCUELSL »
(18.67 KiB) Downloaded 527 times
MOCUELSL
Post by MOCUELSL »
Hola Benj e encontrado el fallo del código te lo envió para que lo puedas revisar e incluir en la actualización esta probado físicamente en una placa con el PIC24FJ1024GB610 con un oscilador de 32,768 kHz.
SALUDOS
MOCUELSL
Post by MOCUELSL »
PIC16BIT_CAL_RTC.c
(9.31 KiB) Downloaded 506 times
MOCUELSL
Post by MOCUELSL »
(116.91 KiB) Downloaded 3609 times
GOOD BENJ DAYS, THE MARKED IN BLUE ARE THE CHANGES I HAVE MADE FOR THE INTERNAL RTCC OF THE PIC24FJ1024GB610 TO WORK WITH A CRYSTAL OF 32,768 kHz. EVERYTHING IS TESTED PHYSICALLY ON A BOARD.
MOCUELSL
Post by MOCUELSL »
PIC16BIT_CAL_RTC.c
(9.42 KiB) Downloaded 559 times
Thanks for letting us know how you overcame the problem and glad it is working correctly for you now.
