EEPROM not compilling in 16F917 and others.
Hi, when i compile to HEX a project that includes an EEPROM module, there's an error message if the project uses a 16F917 and others 16F9XX.
Changing the PIC to a classic 16F877A, everithing goes OK.
Can you help me please?
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Yes, there is a problem with the code generation of the EEPROM component for the 16F9xx devices. We have fixed it here, but it has not been released yet.
For now, here is a workaround. Put the following code into the "defines" box of the "supplementary code" window:
#ifndef eeadr
#define eeadr eeadrl
#endif
#ifndef eedata
#define eedata eedatl
#endif
Better but not enough
Oh, thank you very much.
ItΒ΄s not working yet. ThereΒ΄s still one error:
C:\Documents and Settings\Administrador\Escritorio\EE\Flowcode1.c(168): "#endif" outside of "#if"
What must i do then?
Sorry, Steve. It's working.
I confused the suplementary code with the AddDefines module. Now it's working.
By the way, in my spanish version some names are in english.
Thank you very much, I really love this software.
I can make my own midi controls and guitar switching units now, customized for myself. Very nice
Re: EEPROM not compilling in 16F917 and others.
Hi again.
That old problem is back in the new 3.4.7.48 version.
16f917 not compiles the EEPROM module.
And now the suplementary code you sent me doesn't work neither.
- Steve
I've just tested it here and it works fine. Remember that the code needs to go into the "defines" section of the "supplementary code" window (i.e. the top section).
Yes, Steve, IΒ΄m doing that, just like before.
IΒ΄ll send you the test project.
Here is a simple test. I can simulate it but doesn't compile eaven pasting the suplementary code.
- EEPROM TEST.fcf
- A simple test.
- (5.5 KiB) Downloaded 328 times
- Steve
I've just downloaded this program and it compiles fine here. Can you please also post the "C" file that is generated by your copy of FLowcode - this will help track down the problem.
OK, here it goes:
File name: C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\EEPROM TEST-1.c
Generated by: Flowcode v3.4.7.48
Date: Monday, July 07, 2008 13:11:26
Licence: Professional
Registered to: Ricardo Musso
Launching the compiler...
C:\Archivos de programa\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F917 "EEPROM TEST-1.c"
BoostC Optimizing C Compiler Version 6.70 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
EEPROM TEST-1.c
Starting preprocessor: "C:\Archivos de programa\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\EEPROM TEST-1.c" -i "C:\Archivos de programa\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC16F917 -la -c2 -o "EEPROM TEST-1.pp" -v -d _BOOSTC -d _PIC16
C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\EEPROM TEST-1.c(116): EEPROM error - MX_EEDATA not set
C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\EEPROM TEST-1.c(173): EEPROM error - MX_EEDATA not set
2 errors detected
Error: preprocessing error
failure
Return code = 1
Flowcode no pudo compilar el cΓ³digo C del diagrama de flujo por los siguientes errores:
Si su diagrama de flujo contiene cΓ³digo C, revΓselo cuidadosamente. Si su diagrama de flujo no contiene cΓ³digo C o si ya ha revisado el cΓ³digo C, contactese con Soporte TΓ©cnico.
FINISHED
EEPROM TEST-1.c
2 errors detected
failure
Return code = 1
FINISHED
Sorry Steve.
- EEPROM TEST-1.c
- (10.6 KiB) Downloaded 347 times
Please place the attached file into your Flowcode V3/Components folder and restart Flowcode. Your EEPROM code should now compile correctly.
Default - C:\Program Files\Matrix Multimedia\Flowcode V3\Components.
- EEPROM_Code.c
- (5.99 KiB) Downloaded 415 times
Eureka!
Thank you Benj and Steve. ItΒ΄s working now.
