Recently I used a web server for a wlan chip ESP8266 from FC7. That works well. Is there something similar for the (wired IC) ENC28J60 for FC8?
http://www.matrixtsl.com/mmforums/viewt ... 63&t=19306
ENC28J60 webserver like ESP8266
- Has thanked: 182 times
- Been thanked: 179 times
Re: ENC28J60 webserver like ESP8266
Hello Stefan,
The example here should show you how to host some HTML using the ENC28J60 module.
https://www.matrixtsl.com/wiki/index.ph ... etworking)
It's not quite as nice as the ESP webserver code but it should work well.
Let us know how you get on.
This is working nice with my hardware. Thank you.
Just a small question.....
I get always "Page x Request" as my answer
Do you have a little help?
If I compare the string, there is never a "/" or "/page2.htm",
Compare$ (CompareString,"/",0) = 0
Compare$ (CompareString,"/page2.htm",0) = 0
If I display the string it's always just "GET"
The link "click here for page2" is going to page2 in the explorer but there is no "page2.htm" in the string.
- (6.95 KiB) Downloaded 1532 times
