Problem:
When testing ssd1306(i2c) with Uno in FC8 I noticed that graphics have been displayed OK, but not the text or numbers.
Used:
UnoR3_smd(Chinese), ssd1306(128x64).
File: attached example of FC8_ssd1306_1.
FC8 compilation: no errors.
Programmer: STK-600
What is done
Uno board changed to a new one: the same result
ssd1306 changed to a new one: the same result
Tested with Arduino IDE - OK
Any help please?
ssd1306 text problems (circle-OK)
- Has thanked: 45 times
- Been thanked: 63 times
- Circle_square_text.fcfx
- (9.26 KiB) Downloaded 235 times
- ide_1.jpg (36.78 KiB) Viewed 3592 times
- fc8-1.jpg (33.59 KiB) Viewed 3592 times
Re: ssd1306 text problems (circle-OK)
This is a problem that I believe has already been fixed. Please use the Help -> Check for updates feature and this should provide you with a new LUT component that should solve the problem for you.
Let us know how you get on.
