I just want to know if it is possible in flowcode to compil a new project not with sourceboost but with CCS compiler ?
MIKE_31
new compiler
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: new compiler
This should be possible, but we have not tried it and you will need to do some work:
If you do try to convert Flowcode to CCS, we will try to help and support you where we can (but remember that we do not use the CCS compiler). Please let us know how you get on if you do try.
- You will need to work out what the parameters are for the compiler and linker (the CCS documentation should list these), and set these us in the "compiler options" window of Flowcode.
- The "components" directory of Flowcode contains "C" code files that have the code for the components. You will probably need to change the code in these.
- You may also need to change some of the code within the "code" section of the FCD files you are using.
