Error when compiling to Hex
- Flowcode v5 User
- Has thanked: 19 times
- Been thanked: 16 times
I receive an error when compiling to hex:
/quote
C:\.....\G2\quad G2-2.c(1174): error: missing semicolon
C:\.....\G2\quad G2-2.c(1174): error: failure
failure
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
/unquote
It compiles to C without errors.
Edit: This is the offending line (the 'void... is line 1175)
//Supplementary implementations
void main()
I can mail the source to tech support, but would prefer not to post here.
Thanks in advance,
Jan Didden
/quote
failure
Return code = 1
/unquote
void main()
Thanks in advance,
Jan Didden
- Flowcode v5 User
Re: Error when compiling to Hex
I have isolated the problem to a single C statement. If it is in, I get the error described above. If it is out, it compiles to HEX without errors. The statement is:
#pragma DATA 0x2100, 0x12, 0x34, 0x56, 0x78 ;
to preset some eeprom memory locations.
What am I doing wrong here??
Jan Didden
Jan Didden
Hello Jan
The ; at the end of the line of C code is not required. Hopefully this should fix your problem.
Hello Jan
Which chip are you trying to compile to?
Hello Jan
The 16F865 is not supported by Flowcode. Is this chip name correct?
Hello Jan
Place the code into the defines section of the supplementary code window rather then inside a C code block.
- Flowcode v5 User
Hello Ben,
Sorry for the delay in replying; I have been on a vacation.
Indeed, placing the #pragma for the EEPROM preset in an AddDefines component gets rid of the error message.
Thanks,
Jan Didden
Thanks,
Jan Didden
- Flowcode v5 User
Hello again Ben,
So now I have an AddDefines macro at the start of my program, to enable the AddDefines 'component'.
There are two defines, for the purpose of presetting the EEPROM contents at the moment of downloading the hex code into the 16F685:
#pragma DATA 0x2100, 0x55
#pragma DATA 0x2110, 0x96, 0x96, 0x96, 0x96, 0x96, 0x96, 0x96, 0x96
The values do, however, not show up in the EPROM component window when I simulate the flowchart.
I'm not sure whether it is implemented that way though; it only would seem logical to me that it would appear.
Subsequently in the program I read these preset locations and take actions accordingly.
It works when I manually preset these EEPROM locations before the sim.
Can you enlighten me?
Thanks,
Jan Didden
Thanks,
Jan Didden
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Accurately simulating all C code would be quite tricky, but I can see that implementing certain bits could be beneficial and fairly easy (e.g. the "#pragma data" statements).
So yes - I'll look at allowing you to preset the EEPROM values within the simulation for v4.
