Component for Hx711
- CamargoF
- Has thanked: 6 times
- Been thanked: 7 times
Component for Hx711
I was not able to identify a component for the Hx711 (24-Bit Analog-to-Digital Converter for Weigh Scales) in FC8. Is there any?
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Component for Hx711
If the component does not appear under the component menu's then there is no component for the device.
You can always roll out your own component see this wiki page for help
https://www.matrixtsl.com/wiki/index.ph ... Components you can also use a C icon call and do the necessary
C code to use the device
Regards QMESAR
Regards QMESAR
- petesmart
- Has thanked: 187 times
- Been thanked: 140 times
I have done the hx711....try searching the forum, I think may have posted the code....it was used for my beehive project
If not I will dig it out and drop it on the forum tomorrow...it’s 1am in Oz....so it’s teddy time :
Edit...and here is the link viewtopic.php?f=54&t=18004&p=76393&hilit=Hx711#p76393
Btw... I never got around to turning it into a component..but the code does work..perhaps you can have a crack at turning this into a component and share it on the forum
Enjoy
Best
PETE
Enjoy
Best
PETE
sorry about that Chief!
- CamargoF
Hi Mr. Smart,
I read your post about the hx711 macro in 2016 (FC6), that why I ask my question.
I thought it should be added to the library after two years and two FC releases.
Thank you for your reply.
Best regards,
Fernando
Best regards,
Fernando
Hi Pete,
Would you be happy for us to build a component based on your macro? I've had a quick look and it looks like it should be fairly straightforward.
Edit: It's now done, but I'll wait for your go ahead Pete
- Has thanked: 553 times
- Been thanked: 1081 times
Matrix TSL can not simply grab the code a user supplies and include it in a commercial product. They at least need to have permission from that user (which Benj just asked for).CamargoF wrote:I read your post about the hx711 macro in 2016 (FC6), that why I ask my question.
@Matrix: When FC6 was released there was talk about a component repository/store. With the FC8 update feature in place, can this idea be revisited? (I'm hoping it can be a simple extension of the update system)
― C.S. Lewis
― C.S. Lewis
Hi Jac,
We have some management on board with this idea, others are not so keen. We have lots on atm so I don't see it happening this year but hopefully it will come not too far down the road. The update system certainly does open the door to this type of thing. It's all the other back end stuff to allow users to post components and potentially monetize them that would need attention. We have even talked about no component packs and each component being an individual purchase but at the moment your guess is as good as mine@Matrix: When FC6 was released there was talk about a component repository/store. With the FC8 update feature in place, can this idea be revisited? (I'm hoping it can be a simple extension of the update system)
- petesmart
Go for it Ben....happy for you to use the code on a commercial basis, with no strings attached...
Best
Pete
P.s. @fernando...I don’t work for Matrix, therefore it’s not automatic that Matrix would create a component out of it.. just so you know the forum members create and share code and components freely in the spirit of mutual support..we encourage new members to engage with us in creating projects and sharing...the wisdom of the crowd and sharing is a wonderful thing.
Btw thanks to Ben at Matrix for taking the initiative and creating the component of the back of my code..and Jack I support you idea of a code repository... maybe us forum folk could run it if Matrix create a space...I’m happy to pitch in as I can see the value...it will also address some of the concerns that I have seen recently
what do you all think?
Best
Pete
- QMESAR
Hi All,
I am quite happy to help post some components as we go along if there is place we we can place them and they are central and always in one place
as at the moment the stuff is a bit all over the forum
I support your idea Jac
@Fernando,
As pete said we are small community with a relative small development team(MATRIX) that does wonderful things for us and we on the forum try to help and support as much as we can to the benefit of all FC users ,with that said we also have to have some patcience with things we want and need
it not a quick ask in the forum and the next day you have your request although many times Ben and Leigh are just amazing and produce as today with the Hx sensor.
Ben you are a star as always
Thanks pete for your initial work on the code for the sensor.
@Fernando,
Regards QMESAR
Regards QMESAR
- Has thanked: 1135 times
- Been thanked: 299 times
Hi all!
really a useful component. Unfortunately I am not able to make one. Look forward if it will be added to componentlist.
Br Jorgen
Br Jorgen
- CamargoF
I strongly recommend Matrix to create a open-source component community to make available components from community.
It is the cheapest way to increase the number of developer and to improve the IDE tools.
I suggested you work as Apple do:
(1) Evaluated the component before release it to the community.
(2) In this evaluation Matrix will be "training" programmers to make components.
(3) The released component will have all necessary information to be used, demanding minimal support from Matrix.
(4) Matrix will guarantee the software quality to do not compromise FC.
I will try to help.
I will try to help.
Thanks to all on this, some great comments and suggestions there
I've now pushed the Hx711 component to the Flowcode v8 update system.
Any problems then please let me know.
Hi!
Thank´s to Ben for the component. I already order a handful of hx711 from Ebay ( have some loadcell )
Is it to much to ask for a smal example with a display I can investergate while I am wating for the device. I am unsure how to set it up
Thank´s in advance
Br jorgen
Thank´s in advance
Br jorgen
- (14.66 KiB) Downloaded 4905 times
- petesmart
Hey Jorgen,
Look here...this is the code and macros the component was based on.
This should get you started
Best
Pete
Best
Pete
Hi Pete!
Thank you very much Pete. I can see this examble it is bitbanging, and did not tell mush of these settings in Ben´s component,
please.
Br jorgen
Br jorgen
- (14.66 KiB) Downloaded 4859 times
- CamargoF
I did my own implementation and it is working.
I have two prototypes: with 1 Hx711 and with 4 Hx711.
I would like to know if you could create a video explaining how to create the component, complementing the wiki?
It will be nice if you could explain how can I simulate the Hx711 operation.
Hi carmagof!
Would you share your testprogram. I domt know how to set it up. Please
Br jorgen
Br jorgen
- CamargoF
That is the point.
I was not able to simulate the Hx711 on Flowcode.
The only way I had to test was upload the firmware to Arduino.
On the test I sent all Hx711 reading through the serial USB and use the Arduino serial monitor tool to read the measurements.
That is the reason I asked for the tutorial explaining how to create the component and the simulation interface.
If you want I can share my code with the functions:
- Initialize(): initialize all interface variables and execute Reset() and first reading to set the input port and gain.
- Reset(): force the initialization of the Hx711 and check if it is connected.
- Read(): read the Hx711 returning a positive value (0x00000000~0x00FFFFFF) or 0x01000000 if disconnected.
- Get(): compute the average of 4 readings and convert it to the unit you want (in my case grams).
Hi again.
Ok, thought you have managed to get it run. I misunderstod.
Br .jorgen
Br .jorgen
Hi All!
I just received my HX711 today. Of course testing, but it will not work, I only see 5898 in the display.
I have to admit that I guess in terms of most setting. I can not find anything about this topic anywhere. Will anyone please try to see if I've done it wrong. Please.
Thank´s in advance.
Jorgen
Thank´s in advance.
Jorgen
- LoadcellHX711.fcfx
- (8.9 KiB) Downloaded 416 times
Hi Ben!
You have created the component. I I ask you kindly will you then please tell me the basic for the settings in the HX711 component. The I can start and make my experience. Please.
Scale = ?
Calibrate = ?
Average count= ?
Average_loop_delay = ?
Auto Zero = ?
Or maybe a small exable.
Br Jorgen
Scale = ?
Calibrate = ?
Average count= ?
Auto Zero = ?
Br Jorgen
Hello Jorgen,
I have been playing in the office with one of these modules and think we can make the component easier to use. I'm not 100% on the parameters myself mainly because it's not my code
For now here is a guessed explanation of the parameters.
Scale = Scaling factor, start with 1.0 to give you unity scale and then when you come to calibrate your sensor you can plug in a value here to fit.
Calibrate = Not sure on this one, maybe try 1.0 and 0.0?
Average Count = Number of samples to take in a single operation to try and filter out high frequency noise and spikes
Average Loop Delay = Number of milliseconds to wait in between samples
Auto Zero = 0 for normal operation, 1 to redefine the 0 point as the current reading, imaging a Zero button on digital scales
Regarding scale we are using one of these modules to get a weight from a force plate. The scale factor we have to apply is to divide by 217 to get the weight in grams (after zeroing). This would equate to a scale factor of 1 / 217 = 0.004608
Hi Ben!
Thank`s for reply. Sorry I though it was your component.
Yes, anyway I would be happy If you Will create a new component for Hx711. I already tryed all kind of value in the settings, But nothing it not work. So yes, a working and easy to use Hx711 component which also can be calibrated and tarer is very velcome.
I use a hunghleigh 5kg loadcell.
Br Jorgen
Br Jorgen
I've re-done the HX711 component now so hopefully it is easier to use and understand. The new component should be available now via the update system. Please note that the API for the component has changed fairly significantly so any existing programs will become broken.
I've also added simulation functionality using a slider and added an example here.
https://www.matrixtsl.com/wiki/index.ph ... _(Sensors)
Let me know how you get on.
Hey man, Thank you Ben.
I am not home now, in the evening and then I make a test and you will be the first who hear the result.
Thank´s.
Br jorgen.
Thank´s.
Br jorgen.
