How to stop and collect a Keypad Digit
- JLeith
- Has thanked: 146 times
- Been thanked: 26 times
Hello All.
Well at this moment I have not been able to recover my Old Flowcode Design from my failed Laptop Drive.
I was able to find a copy from the forum during past help.
It works 85%. And my mind is running in circles.
I have a Macro call when the Digit "0" is pressed it runs a Reset Macro.
The steps I trying to follow that other programing in my flowcode will not work not work in my new Reset Macro.
I have 4 steps and just focusing on just 1 to work.
Steps.
Press "0"
'0' is routed thru the "Keypad" Macro.
The "0" selection runs Macro Reset.----Works.
Now in Reset I need a selection ?
Press 1 --- Score
Press 3 - Pitch
For some reason beyond my findings I can not get the program to wait for the Selection and then run the little Branch to play a message.
In the future I will do some calculations in the Branch.
Currently when you press "1" it runs off and adds a count to Home team pitch.
I have added my Flowcode.
I know I'm missing a step just can't see it........
John
Steps.
Press "0"
Press 1 --- Score
Press 3 - Pitch
John
- Count Master with Keypad Sept 5 2018.fcfx
- (166.45 KiB) Downloaded 246 times
Re: How to stop and collect a Keypad Digit
Hi John,
Good to see you back on the forums as well.
I have spotted two issues within Keypad macro: 1) You have got a keypad component macro to first detect what key you pressed then another keypad component macro to wait until a key is pressed.
Doing that way around will not detect which key has been pressed.
You need to wait for a key pressed, then detect which key is pressed.
The other issue is never to use a call macro in this case Keypad to call itself!
Use a conditional loop instead.
If you want the loop to run at least once as in this case then selectEnd
However, within Keypad function macro, you have got a decision branch:
Near the end you have then call the Key Keypad function macro.
Start is never going to be 2 at this point, so don't know why you are calling the Keypad function macro again??
Hop this helps you to get further.
I have not checked the rest of the flowchart, just one step at a time.
Test the loop at the:
If Start = 2
Start = 0
- JLeith
Hello Martin
I tried the steps and for some reason if I removed them the Selection for 2 & 8 won't work. The action of Start = 2 is activated when the Selection of "5" so the selection of 2 and 8 only appears once.
After this investigation on the Keypad selection the Selection for 5 and 2 or 8 are working.
I'm going back to the Reset macro to do digit capture and see if I can get it to work.
John
John
No I'm not suggesting to remove them.JLeith wrote:if I removed them the Selection for 2 & 8 won't work.
The order needs swapping.
So it's
Wait first then GetAscii after!
- JLeith
I missed that step.
Off to correct.
Martin do you recall back in the day how to collect 2 digits from the keypad.
I recall a loop to get the 1st digit and then a loop to get the 2nd digit and then a formula to combine the two values.
Like Digit 1 = 2
Like Digit 2 - 4
The Sum of the Digit is 24
John
Off to correct.
Like Digit 1 = 2
Like Digit 2 - 4
John
Hi John, glad you are all sorted now.
This may or may not be of interest to you?
