how can i use multi function shield for arduino
bilal
Has thanked: 1 time
Post by bilal »
hi
how can i use multi function shield in arduino.
i need Arduino Library for this shield.
thanks.
katela
Has thanked: 3 times
Been thanked: 1 time
Re: how can i use multi function shield for arduino
Post by katela »
You don't really need a specialized library to use that shield.
You can read its datasheet to find out where each device is connected to and use normal Flowcode components and icons to control it. A shield is just making simpler to connect devices to arduino pins, but the underlying connections are still the same even without a shield.
Free online Microcontroller Tutorials & Projects for beginners to advanced.
Website: https://www.studentcompanion.co.za/cate ... e-for-pic/
YouTube Tutorials: https://www.youtube.com/user/StudentCompanionSA
bilal
Has thanked: 1 time
Post by bilal »
katela wrote:You don't really need a specialized library to use that shield.
Yes you are right, but when there is a library that is easy to program.
Keys and LED are easy to deal with and programmed as you said, but the seven-SEG need a library to make it easier to program>
can you tell me what is the correct components for the 7 segment in flowcode v8, for the arduino multi function shield.
thanks
The shield looks interesting.
I can make an example project to drive the shield or maybe even a component. Which microcontroller device are you using? i.e. Is it an Arduino Uno or a different device? This will allow me to correctly pre-configure the various component pins.
The only information I have currently found on the board is here.
http://www.cohesivecomputing.co.uk/hack ... on-shield/
If you have any better links to information e.g. a schematic then that would be helpful.
bilal
Has thanked: 1 time
Post by bilal »
Benj wrote:Hello,
thanks.
I use Arduino Uno, and I need to be programmed by Flowcode program.
Can you program me an example, a counter of 1 to 10, using a flowcode program.
bilal
Has thanked: 1 time
Post by bilal »
Thanks for help
can you make an example, to write a number ten, in the seven-sagment in arduino multi function shield.
Without actually seeing a schematic I can only go off the library code and it looks like there is some sort of buffer IC that drives the 7-seg displays.
Here is a quick example that simulates and should also hopefully drive the hardware.
Shield.fcfx
(18.68 KiB) Downloaded 295 times
Let us know how you get on. The board looks quite well suited to create a component to drive it.
bilal
Has thanked: 1 time
Post by bilal »
Benj wrote:Hello,
Shield.fcfx
thanks to much.
