18f4550 usb issues
Roy Johnston
Flowcode V4 User
Has thanked: 2 times
Been thanked: 34 times
18f4550 usb issues
Post by Roy Johnston »
I need to use ports C4 and C5 in the PIC18f4550. However, the datasheet says:
"To use pins RC4 and RC5 as digital inputs, the USB module must be disabled (UCON<3> = 0) and the on-chip USB transceiver must be disabled (UCFG<3> = 1)."
can someone help me with the config setting in flowcode please.
Has thanked: 114 times
Been thanked: 422 times
Re: 18f4550 usb issues
Post by Steve »
I think this should work...
At the start of your program, add a C-icon and enter the following:
UCON = 0x00;
UCFG = 0x08;
Roy Johnston
Flowcode V4 User
Thank you,
unfortunately it is not helping.
I attached my flowcode.
I simply cannot read the two inputs as inputs.
is it not possibly the standard config in Flowcode overriding this instruction.
controller_3_Tester.fcfx
(50.27 KiB) Downloaded 217 times
Roy Johnston
Flowcode V4 User
I have basicly done a simple flowcode only to test this function, it is not working.
usb_input.fcfx
(17.87 KiB) Downloaded 308 times
Post by Steve »
There seem to be lots of issues with these pins on that chip. Another suggestion from my searches is to add these to the C-icon:
ADCON1 = 0x0F;
CMCON = CMCON | 0x07;
Unfortunately, I don't have suitable hardware to hand so I can't test.
Roy Johnston
Flowcode V4 User
Thank you for trying,
unfortunately it did not help.
This is the code we use on the 18F4550 devices to initialise them with all I/O.
ADCON0 = 0x3D;
ADCON1 = 0x0F;
UCFG = 0x08;
cr_bit(PIE2, USBIE);
Hopefully this will work for you.
The pins C4 and C5 should hopefully now work as inputs, the pins cannot be used as outputs.
Roy Johnston
Flowcode V4 User
thanks for the help but Unfortunately it has not helped.
. I have written a basic program, that reads 3 inputs and switches 3 outputs. input D4 works perfectly C4 and C5 don't , the following happens. if C4 is high or low the output is low. if C5 is high or low the output is low. if C$ and C5 is high then both outputs are high, however it remains high irrespective of the inputs. [attachment=0]usb_input.fcfx
usb_input.fcfx
(9.55 KiB) Downloaded 222 times
Roy Johnston
Flowcode V4 User
thanks for the help but Unfortunately it has not helped.[attachment=0].
usb_input.fcfx
(9.55 KiB) Downloaded 227 times
Roy Johnston
Flowcode V4 User
Thank you for all the help.
I came right.
it ended up being the chip not functioning the way it should have.
I replaced the 18F4550 and all is well now.
all we need to do is disable the usb voltage regulator (bit 21) in the config parameters and it works like a charm.
