First time attempt at Flowcode. It is producing multiple errors so I could be miles off.
The idea is to produce some different tones from an alarm board out of my scrap box, I have have chosen a 12F629 as it has the same pin count as the original 12c508. It works fine on simulation, one uncertainty is with the switch as I have only got bits 0 to 5 to read on the port I have used 6 bits in the condition (0bxxxxxx).
Target folder: C:\Users\Owner\DOCUME~1
Source name: C:\Users\Owner\Documents\sounder_12F629.fcfx
Title:
Description:
Device: PIC.12F.12F629
Generated by: Flowcode v8.0.0.6
Date: Tuesday, November 13, 2018 10:39:45
Users: 1
Registered to: ianjoh
License key: DTHTBY
NOT FOR COMMERCIAL USE
http://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat 12F629 "C:\Users\Owner\DOCUME~1\" "sounder_12F629"
C:\Users\Owner\DOCUME~1>C:\PROGRA~3\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=12F629 "sounder_12F629.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
using updated 32-bit floating-point libraries; improved accuracy might increase code size
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_IO.c: 216: non-reentrant function "_FC_CAL_Port_In_DDR__x" appears in multiple call graphs and has been duplicated by the compiler
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_Delay.c: 85: non-reentrant function "_delay_us" appears in multiple call graphs and has been duplicated by the compiler
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_Delay.c: 152: non-reentrant function "_FCI_DELAYINT_US" appears in multiple call graphs and has been duplicated by the compiler
sounder_12F629.c: 744: non-reentrant function "_FCD_0ba81_PiezoSounder1__BuzzerOnDelay" appears in multiple call graphs and has been duplicated by the compiler
C:\PROGRA~3\Flowcode\Common\COMPIL~1\pic\sources\common\fltol.c: 43: non-reentrant function "___fltol" appears in multiple call graphs and has been duplicated by the compiler
C:\PROGRA~3\Flowcode\Common\COMPIL~1\pic\sources\common\sprcdiv.c: 8: non-reentrant function "___fldiv" appears in multiple call graphs and has been duplicated by the compiler
C:\PROGRA~3\Flowcode\Common\COMPIL~1\pic\sources\common\sprcmul.c: 8: non-reentrant function "___flmul" appears in multiple call graphs and has been duplicated by the compiler
C:\PROGRA~3\Flowcode\Common\COMPIL~1\pic\sources\common\xxtofl.c: 10: non-reentrant function "___xxtofl" appears in multiple call graphs and has been duplicated by the compiler
C:\PROGRA~3\Flowcode\Common\COMPIL~1\pic\sources\common\Umul8_16.c: 4: non-reentrant function "__Umul8_16" appears in multiple call graphs and has been duplicated by the compiler
Non line specific message: (1359) no space for ___xxtofl parameters
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
FINISHED
Newbie compile errors.
Re: Newbie compile errors.
Hi Ian,
Welcome to Matrix forums
It looks like the device you have selected has run out of memory.
Also, one very important rule to observe.
Its best not to use the same component within an interrupt that's used elsewhere.
E.g Sounder component in both Normal call macro and interrupt call macro
I have converted your flowchart to use the more superior 12F1840.
It's being run with internal osc of 16MHz as I don't know if power should be kept to a minimum or not?
These devices can run with internal osc of 32MHz if required.
- sounder_12F1840.fcfx
- (19.34 KiB) Downloaded 239 times
Hi Martin
Thank you so much for your prompt reply.
I have been digesting your changes - its takes a while!
The reason behind the interrupt was to break the 8 second timer on the Normal macro so there would be no delay to switching to the emergency tone should the timer be active. Could you suggest a way of doing this if I cannot use the macro in the interrupt as I was?
Is there a way of checking for remaining available memory as the project is being built?
Ian
Ian
Hi Ian,
Take a look at at attached flowchart, in the normal call macro. That is one way of overriding the 8 sec delay if interrupt is triggered (independent of osc speed)
The only way I know of to check memory as you go is to keep compiling to hex.
Then the available memory remaining will be displayed.
- sounder_12F1840 V2.fcfx
- (19.95 KiB) Downloaded 256 times
Hi Martin
That's brilliant - thank you. I think I will apply it to the toilet call macro as well to neaten it up.
Ian
Ian
Hi Ian,
You're welcome.
I did notice I made a mistake, sorry about that.
Can you change
to
If you did not already know:
|| = logical OR
&& = logical AND
Logical is used for calculations whereas bitwise (& |)are used for bit masking and manipulation.
You can single step flowchart by pressing F8 then use mouse to press buttons and observe what happens.
The INT0 interrupt does simulate OK.
Alternatively, you can use the keyboard to trigger a button.
It's called Key mapping
If you need help with that then let me know.
You're welcome.
Can you change
(Loop < 160) || (INT0TriggerFlag = 1)
(Loop < 160) && (INT0TriggerFlag = 0)
|| = logical OR
&& = logical AND
