Hi all
I use a PIC10F204 for a simple project.
I need actived a led when the voltage at the pin GP0 is major at the 06V, internal refernce voltage at the comparator.
I read that the flowcode not simulate the internal comparator, is correct?
when I tried at connect a potentiometer at pin GP0 for simulate,is not was possible, why?
i tried set a comparator with C code, is it possible?, and the internal register, for example "CMCON0" is simulated in flowcode?.
for this simple project I can programmer in assembly code, but I would like tried wìth flowcode. thankyou for your advises and sorry for my bad english.
I attack an example
Comparator PC10f204
Re: Comparator PC10f204
Currently Flowcode doesn't support internal comparator modules. If you want to use them you have to use your own C code inside C icons to drive the peripheral registers. We have tried a number of times to include comparators but they differ so much from device to device that it quickly gets very complicated.I read that the flowcode not simulate the internal comparator, is correct?
The ADC components require an ADC peripheral and an ADC capable input pin. The 10F204 has neither of these features just a comparator.when I tried at connect a potentiometer at pin GP0 for simulate,is not was possible, why?
The C code icons won't simulate, they will be ignored by the simulator. However they will compile and work on the target device.i tried set a comparator with C code, is it possible?, and the internal register, for example "CMCON0" is simulated in flowcode?.
You are very welcome and your English is very good, both clear and understandablethankyou for your advises and sorry for my bad english.
Thanks Benj
All is clear, I'll try tomorrow.
Flowcode is very good, I'm not a programmer, I'm hardware specialist, and flowcode for me is perfect for realized a my Christmas project.
only question, exist one list of command "C" code correct or different for flowcode?,
for example,
tes_bit , set_bit ecc.
thankyou very much
for example,
thankyou very much
For general purpose bit manipulation using a C code icon you can call these functions.
for example
Will set bit 0 in the MyVar Flowcode global variable.
For more specific register manipulation on a PIC device where you want to specifically reference a bit in a register by name you can also use these functions.
for example
You can refer to the device datasheet for the register names and bit names.
set_bit(var,bitno) //Sets a single bit
clear_bit(var,bitno) //Clears a single bit
test_bit(var,bitno) //Tests a single bit Code: Select all
set_bit(FCV_MYVAR, 0);For more specific register manipulation on a PIC device where you want to specifically reference a bit in a register by name you can also use these functions.
st_bit(var,bitno) //Sets a register bit
cr_bit(var,bitno) //Clears a register bit
ld_bit(var,bitno,val) //Loads a register bit as a 0 or 1
ts_bit(var,bitno) //Tests a register bit and returns true or false for example
cr_bit(TRISA,TRISA0); //Convert Port Pin A0 into an output
st_bit(PORTA,RA0); //Set output pin A0 highRegards Ben Rowland - MatrixTSL
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Hello!
I attach an example.
Not tested in hardware.
- COMPARATOR_10F204.fcfx
- (9.58 KiB) Downloaded 321 times
I tested firmware send from STibor, perfect funcionally, I changed only configuration pin "CIN-" because I used internal reference value.
For me is very important understend "C code" icon, your example is very exaustive.
Thankyou very much
Thankyou very much
