Eeprom Pic32MX340F512H error compiler
Ferla
Flowcode v5 User
Been thanked: 19 times
Post by Ferla »
Hi guys
I can not get the EEprom component to work with PIC32 bit.
Have any of you tried? FC error to Compilers\pic32\bin\xc32-gcc.exe report error code 255
Do you have a simple 32bit working example?
Thank you
Ferla
Ferla
Flowcode v5 User
Re: Eeprom Pic32MX340F512H error compiler
Post by Ferla »
I'm reading that it has no internal EEprom but only Flash that has been used as an EEprom simulation :roll:
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi.
Most 32 bit Processors does not have EEPROM such is the case with PIC32
You have to write to Flash from your code,I am not sure but think FC does not have a component for flash rights
Ferla
Flowcode v5 User
Post by Ferla »
Thanks Qmesar , so I read well. I will change the chips or connect external eeprom.
Ferla
