ST ARM HAL Pull up/down pin?
chad
Has thanked: 27 times
Been thanked: 33 times
Post by chad »
I spent a couple of hours trying to figure this out didn't have any luck. I am sure it is going to have to be a little c blurb.
I have some buttons I would like internal pull up / down resistor. I know there is a HAL command to do this but I don't know anything about the HAL library.
Has anyone done this on an starm?
Thanks!
Chad
edit: for clarity.
chad
Re: ST ARM HAL Pull up/down pin?
Post by chad »
A little update:
A friend helped me figure this out.
GPIO_InitTypeDef GPIO_InitStruct = {0};
  /*Configure GPIO pin : PC1 */
  GPIO_InitStruct.Pin = GPIO_PIN_1;
  //GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  //GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  GPIO_InitStruct.Pull = GPIO_PULLUP;      //GPIO_NOPULL, GPIO_PULLUP or GPIO_PULLDOWN
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Hi Chad,
It is possible to do the pull-up/down with C code, such as using the HAL.
It can also be done by writing directly to the registers, for example..
// Port c pin 0 pull up
GPIOC->PUPDR |= 0x00000001 ;
// Port c pin 1 pull down
GPIOC->PUPDR |= 0x00000008 ;
However, there is another issue, in that when we implement the input icons of a flowchart the HAL initialization is called,
this will turn the pulls back off again.
This is all to do with how Flowcode has historically been implemented to make things easy for the user.
We have some ideas on how to avoid this with ARM, but haven't implemented them yet to avoid upgrades breaking projects.
So if you set the pulls in C code in your project you are then best reading the input directly in C code too.
Either directly at the register...
FCV_X = GPIOC->IDR & (1 << PIN_NUMBER);
or use the Flowcode CAL function, which will also set the pin to an input for you...
FCV_X = FC_CAL_Bit_In_DDR__x(GPIOC, PIN_NUMBER);
Hope that helps,
Leigh
chad
Post by chad »
Hi Leigh,
Thanks for the extra info, super helpful! I was worried about 'double' setting pins, seemed to work ok in my test but I can see how it could be a problem.
Thanks again,
Chad
