hello Ben... okay so another bug...
So I went and looked at the PrintNumber option in the LCD print routine....
and... okay - so...I was wrong.. I used... the wrong command....!!
I should have used... the
PrintFormattedNumber.....!! yay..!!!
However... when I put that into place... it was very exciting....
BUT... Gee then... another bug.!!! jumped out the screen at me....
So in the LUT ... table... I edited the numbers to their correct... exact looks... like 03110 ... and 0116784453 ...
AND damn damn... damn ... the first number comes out as 1608 ...when I print the 2nd number...in the sequence.. it just returned a BIG FAT ZERO.!!!!
So instead of... getting... like 0116784453 as the number... it comes out as a BIG FAT 0...!!!! Damn Damn....Damn....
So just to clarify...I tried the first number in the sequence again... which is 3110... and made it... 03110 ... and then strangely - it returned... 1608 ... why this should be so I do not know...??????
gee it's really frustrating to KEEP FINDING BUGS..!!!!
How does one do anything - really nice with FLOWCODE... when you always - finding bugs..!!!... and then you have to pay for it as well.!!!!!
Hell- I hope I'm wrong... I really do...!!!!..
Kindest Regards
ole Spens...
the LUT .... has these numbers in...
03110,0116784453,03111,0837874453,03112,0717434842,03120,0114761234,
so they have to come out exactly like that ... index 0 = 03110 ... index 1 = 0116784453... index 2 = 03111... index 3 = 0837874453... etc etc..
LUT ... problem..
Re: LUT ... problem..
Hi Spencer,
It's not a bug.
A number starting with 0 gets treated like octal and not decimal.
Just like 0x is hex and 0b is binary.
I don't believe flowcode is designed to display oct values?
As 3110 dec = 6046 oct
It's not a bug.
If you need the "0" to be printed to the LCD then you can simply print the "0" as a string before then printing the number. e.g. 3110.
Hey guys - you talking RUBBISH.!!!!
the software - should cater for whatever number I put into the LUT...
IT IS A LOOK UP TABLE.... and so whatever number I put in there - should come out exactly the SAME.!!!.. the LUT is a STORE..!!!!
NOT SO...
What is the use of a LOOK UP TABLE changing the values - THAT's PURE RUBBISH..!!!!
So please....!!! get with it...!!!!!
So I put a number into an EEPROM...!!! OR an SD CARD.... and then you reckon - when I take it out the SD CARD.... it's gonna change...
I hope you never write software - for me anywhere,,!!!!
Thank you - now get to it - !!! FIX THE BLOODY SOFTWARE..!!!!
NOT SO...
mnf
- Has thanked: 70 times
- Been thanked: 440 times
If you want it to show exactly what you put in then save it as a string.. One byte per digit
Otherwise a number could be
1234
01234
001234
By convention numbers are not displayed with leading 0s and of you want it to be so then you'll have to do some of the work yourself.
As mentioned above by convention octal numbers are entered into code using a leading 0 ( because who puts leading 0s onto numbers)
So, no, not a bug.
1234
01234
001234
So, no, not a bug.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
As Martin mentioned, the LUT is for numeric values, not strings.
https://gcc.gnu.org/onlinedocs/gcc/Bina ... tants.html
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Well the solution is easy if you do not like how a component functions Roll out your own that does what you want ,Flowcode give you all the tools to make your own Component in this case a tablethe software - should cater for whatever number I put into the LUT...
NOT SO...
Regards QMESAR
Regards QMESAR
