Hi All
Just looking for some help and some suggestions on how can fix this problem
The PIC Programmer gets detected in windows just fine, but when I try and send programs to it, nothing happens just get a press the reset button etc error,
Now when I run the program as admin it then starts to work how it should, IE the program is successfully wrote to the board. However that will require our students to input admin student and password which they won’t have.
I have tried giving all users special permissions but that doesn’t seem to have done anything.
Is there any reason why the program will only function as run as admin and if so how can I fix it?
Kind Regards
Liam
Problem with BL0011
Re: Problem with BL0011
Hello Liam,
Can you attach you project so we can have a look for you.
It sounds like your project is maybe setup for the wrong target device, the BL0011 should not pop up a reset message.but when I try and send programs to it, nothing happens just get a press the reset button etc error,
I have attached the program that we have been trying to run.
i did try to adjust the targeting in the program but didn't know if it had worked
- temp.fcfx
- (5.8 KiB) Downloaded 1423 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
This sounds like Group Policy restrictions on the use of USB devices.
Do you have an IT department that could help with this?
What version of Windows are you running?
