write error but still works most of the time
Forum for problems or queries regarding the Flowcode application and compiler usage.
bgraham55
Post by bgraham55 »
I get the following write error when I complie to the chip on the flowcode buggy.
Error: 31USB Write Failed
Failed with error 31: A device attached to the system is not functioning.
However the program down loads and in most cases the program will ru. Howeever it does not always work.
Any Ideas wht the problem may be?
Bill
Re: write error but still works most of the time
Hello Bill
Yes you are correct, the error is reported but the program is going into the buggy ok. You can download the latest version of the buggy software from here. This version does not have the programming error problem.
http://www.matrixmultimedia.com/softwar ... rammer.zip
