scada slaves
DavidJ
Has thanked: 1 time
Been thanked: 3 times
scada slaves
Post by DavidJ »
Have tried to use Scada slaves using arduino
But have had only limited success
The setoutpin function works fine no problem
But when i try to use Getinputpin function
ie when i toggle PIN 8 high and low on the arduino
The Getinputpin function does not change in the 'Arduino' console window or the 'in' varaiable and reads 1 all the time
However I can see the status correctly change in the 'UART1' console window on the Scada
ie 8 1 129 and 8 0 129
So it would appear the Scada is seeing the change from the arduino but not reporting it fully correct
Any ideas ?
Re: scada slaves
Can you post your program so we can see what you're doing and try to replicate the issue.
DavidJ
Has thanked: 1 time
Re: scada slaves
Post by DavidJ »
Enclosed files
David
SCADA_Firmware_REV01.fcfx
(63.22 KiB) Downloaded 210 times
SCADA_SLAVE_TEST_REV01.fcsx
(8.88 KiB) Downloaded 207 times
Re: scada slaves
Hi David,
I believe I have found and fixed the problem for you.
The SCADA Slave firmware was receiving the command and responding correctly but the Flowcode simulation had a chance of getting out of sync with the response. I have now added code to the initialise function of the SCADA Slave component so that it re-syncs itself and this seems to be working nicely for me now.
I've pushed the changes to the v8 update system and also updated all the other SCADA Slave components with the fix.
Let me know how you get on.
DavidJ
Has thanked: 1 time
Re: scada slaves
Post by DavidJ »
Ben
Thats great now works fine
Thanks for your assistance
David
