PWM signal < 10 HZ
xelites
Been thanked: 7 times
PWM signal < 10 HZ
Post by xelites »
Who can help me thanks, I have to generate a PWM signal with a base at 20HZ or 10 HZ and variable from 0 to 100% ... the original component of the micro does not make me go below 1000HZ. Thanks sorry the trouble.
Re: PWM signal < 10 HZ
Hi xelites,
I have answered a similar question here
xelites
Post by xelites »
I see medelec, but the page link after not present server 404 error ! i not find example ... :(
Hi xelites,
Sorry I did not know the link is broken.
I can create an example flowchart for you.
What would be your preferred frequency?
xelites
Post by xelites »
Thank you. I use the 18F67K22 and I have to emulate a PWM with a base frequency of 20 HZ. Thanks again
No problem.
Are you using internal or external osc and at what frequency?
If you are not fussed, then I created a quick example with internal OSC at 16MHz
It may be best to complete a 1sec flasher test to make sure chip is running at the correct osc speed.
Bit Bang PWM1.fcfx
(11.22 KiB) Downloaded 211 times
xelites
Post by xelites »
I used ext osc. a 16 MHz PLL active a 4X ( 64MHz ).
To day i try your example
xelites
Post by xelites »
Medelec but what version do you have of FC8? tells me you have compiled it with a newer version of 8.1 ... and that may not work! :)
I'm running 8.2.0.12 in which patch was downloaded from here
What I do every so often is while I have a flowchart open, Select Help, Check for updates.
Change Files in-use to Full database
So long as you are running 8.2 there will be no issues with not working due to version differences
