Have tried to compile a pice of code and get a compiler error for the charlieplex module
posting.php?f=63&mode=post&sid=dcce8c3c ... 8c0fef279a#
Source name: C:\Intelligas\GDMS Exp 1\Exp8_V1.fcfx
Title:
Description:
Device: PIC.16F.16F1615
Generated by: Flowcode v7.3.0.5
Date: Saturday, August 31, 2019 14:19:09
Users: 1
Registered to: bARRY wETTON
Licence key: K4RR9E
NOT FOR COMMERCIAL USE
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe --chip=16F1615 "Exp8_V1.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
Exp8_V1.c: FCD_02191_led_charlieplexed1__AllOff()
1611: FCL_DUMMY = (FC_CAL_Port_In_DDR__x((&FCP_PORT_B), (&FCP_TRIS_B), (0x1), (0x0)));
^ (192) undefined identifier "FCP_PORT_B"
(192) undefined identifier "FCP_TRIS_B" ^
1617: FCL_DUMMY = (FC_CAL_Port_In_DDR__x((&FCP_PORT_B), (&FCP_TRIS_B), (0x2), (0x1)));
1623: FCL_DUMMY = (FC_CAL_Port_In_DDR__x((&FCP_PORT_B), (&FCP_TRIS_B), (0x4), (0x2)));
1635: FCL_DUMMY = (FC_CAL_Port_In_DDR__x((&FCP_PORT_B), (&FCP_TRIS_B), (0x8), (0x3)));
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
Is this something that can be fixed quickly. Please help
Barry W
PIC16F1615 compiler error
Re: PIC16F1615 compiler error
Hi Barry,
Something wrong with the link.
Can you fix the link or post flowchart please?
Hi Medelec35,
Have attached the full file it is for an 8-1 multiplexer.
- Exp8_V2.fcfx
- (37.93 KiB) Downloaded 222 times
Hi Barry,
Your flowchart compiles for me:
I have noticed you are running an older version of Flowcode.
Can you make sure you have 7.3.0.7
You will need to visit this post To update with the latest version (first post).
Source name: M:\Flowcode Testing\Exp8_V2.fcfx
Title:
Description:
Generated by: Flowcode v7.3.0.7
Date: Monday, September 02, 2019 13:40:52
Users: 1
Registered to: Martin
Licence key: BA48R5
M:\Flowcode 7\compilers\pic\bin\xc8.exe --chip=16F1615 "Exp8_V2.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler (PRO Mode) V1.41
using updated 32-bit floating-point libraries; improved accuracy might increase code size
M:\Flowcode 7\CAL\internals.c: 72: (1090) variable "_FCI_TMP_INT" is not used (warning)
M:\Flowcode 7\CAL\internals.c: 71: (1090) variable "_FCI_TMP_STR" is not used (warning)
Exp8_V2.c: 1540: (1090) variable "FCD_02191_led_charlieplexed1__LEDOn@FCL_DUMMY" is not used (warning)
Exp8_V2.c: 1726: (1090) variable "FCD_02191_led_charlieplexed1__AllOff@FCL_INDEX" is not used (warning)
Exp8_V2.c: 1727: (1090) variable "FCD_02191_led_charlieplexed1__AllOff@FCL_DUMMY" is not used (warning)
Memory Summary:
Program space used 401h ( 1025) of 2000h words ( 12.5%)
Data space used 34h ( 52) of 400h bytes ( 5.1%)
EEPROM space None available
Data stack space used 0h ( 0) of 3CCh bytes ( 0.0%)
Configuration bits used 3h ( 3) of 3h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
M:\Flowcode 7\tools\DoNothing\DoNothing.exe
FINISHED
You're welcome Barry,
Glad it's now working.
Thanks for letting us know.
