Modbus tcp/ip master/slave simulation problem
kabouras_33
Has thanked: 8 times
Been thanked: 8 times
Re: Modbus tcp/ip master/slave simulation problem
Post by kabouras_33 »
Last note for today!! :mrgreen:
I used modbus poll software in various situations and i works perfect until now so i think that if we manage to communicate flowcode slave with modbus poll we are done :wink:
I stop now because brain salad.
Goodnight!!!
kabouras_33
Hello!!!
Further update today i tried a flowcode master with simulation slave....the simulation could read coils correctly but not holding registers....
Well by now i dont know if i am helping or i am in completly the wrong direction...
Awaiting your feedback
Thanks again!!!
kabouras_33
hello again,
i think that the check for incoming macro doesnt give correct responce...
i keep searching awaiting your feedback
I'll see if I can replicate this problem for you and hopefully provide a fix.
kabouras_33
Dear Benj,
Hello!! So after some time, i could make the esp8266 work :wink:
The solution is tricky to explain but it looks like flow code components target the wrong index to retrieve or send data to other except flow code,
I wrote my own software in unity 3d and I could locate the problem.
No, the problem is with the w5500 which still I cannot understand why it doesn't work!! (a very simple example would be awesome!!!)
and secondly
I noticed in the slave Modbus TCP there is a macro GetLastIncoming.....
I believe I can retrieve specific info with that macro from the incoming message...
Well, I want to retrieve the address number from the incoming message (index 2) but I have no idea how???
any pointers?
kabouras_33
Cannot make it work!
esp8266 works very good but w5500 just refuse to connect....am i missing something?
A little help please??
SLAVE MODULE1.fcfx
(23.44 KiB) Downloaded 351 times
kabouras_33
No go...i tried as Modbus TCP slave enc28j60,w5500,w5100 all of them no go
I can ping them but they do not appear on my routers or work of course...
ok, I am waiting for your kind assistance because at least the w5500 which says supported should work but no so I am doing something wrong definitely.
Thanks for letting us know of the problem, the W5500 should certainly be working so let me investigate this for you.
kabouras_33
Thank you Benj,
and if you need anything from me, test,or send you data please tell me!
i will be most happy if i can be of any assistance
TaliG
Has thanked: 16 times
Been thanked: 14 times
Post by TaliG »
Dear Benj,
I am stuck with the same problem.
I am using Codesys with rasberryPi as a Master, EB091 plus W5500 as a slave.
ModbusTCP with W5500 gives invalid header response.
UART Modbus RTU works great.
Any news on a fix?
Thanks!
rpiRTU.fcfx works great
rpiTCP.fcfx connects but returns wrong response values.
rpiRTU.fcfx
(16.03 KiB) Downloaded 314 times
rpiTCP.fcfx
(16.97 KiB) Downloaded 332 times
kabouras_33
Hi,almost a year now...any updates???on the bug...
A few months ago I looked into this and provided a fix for the TCP modbus components to fix the header. Please check you are using the latest updates using help -> Check for updates.
Here was the topic where we investigated the problem.
https://www.flowcode.co.uk/mmforums/view ... 56#p101856
If you are using the latest files then let me know and I'll have another look into it.
kabouras_33
Ooo i lost that!!!!
Awesome!!!!i am planning to incorporate it in another system so thats great timing!!!!
Thanks you are the best once again!!!
TaliG
Post by TaliG »
Hi kabouras!
Modbus TCP protocol replies are already fixed by Benj.
At least w5500 works fine for me (communicates correctly with modbus poll).
Please take a look at this thread https://www.flowcode.co.uk/mmforums/view ... 78&t=22101 and download my test flowchart using w5500 that works great with modbuss poll. (last post).
About esp, I have not tested anything yet, I am waiting some new boards with esp-07s to start play with.
but on the above topic Benj corrected everything about the protocol and the w5500 can communicate correctly with modbus poll.
George
