A little bug in V5
Crenwick
Has thanked: 7 times
Been thanked: 21 times
A little bug in V5
Post by Crenwick »
I'm working today for the first time on V5 with a new project and are facing a little bug (maybe the first :wink: )
When I try to write to Eeprom the result is allways 0. When I try the same prog on V4 it's ok so ...
I attached a little demo.
My project is an automatic phonedialer for my alarm system and I need to store my cell number in Eeprom :)
Can you please check ?
Is it also possible to create a V5 folder on the forum ? :wink:
And how can I change the version of Flowcode in my signature ?
Sorry for all the questions :oops:
Bernard
Eeprom test.fcf
(6 KiB) Downloaded 437 times
Bernard
Flowcode 6 / EB006-V9
petesmart
Has thanked: 187 times
Been thanked: 140 times
Re: A little bug in V5
Post by petesmart »
I understand that you do not have the issue with V4, however on certain chips under circumstances that I have yet to fully identify, I have had reliability issues with writing to location 0 on the physical chip. Simulation works fine, however to ensure repeatable success on the hardware I have adopted a practice of starting from address location 1 skipping address location 0.
Not sure if this helps, however it might be worth a try.
All the best
Pete
sorry about that Chief!
Crenwick
Post by Crenwick »
Well I tryed on two different chips on the ten first positions and wathever I try to write it's allways 0.
Sorry for Matrix Staff to give you extra work :wink:
Bernard
Bernard
I can confirm that this is a simulation only bug and that the code is working as expected on the hardware. At least for the 16F88 device which I have just tested.
Crenwick
Post by Crenwick »
Thanks Ben,
By the end of the week I will be ready with my PCB.
You all at Matrix have done a big job :wink:
Bernard
Bernard
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Hello!
I would like to write a lcd screen UINT, ULONG, and Long variables.
I see the V5 Flowcode LCD screen print numbers are manageable variables<= Int. A later improvement in the macro lcd?
counter.fcf
(9 KiB) Downloaded 430 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
You can write signed long integers to a string using the ToString$(variable) function. You can then write this string to the LCD.
Create a calculation and type:
buffer = ToString$(variable)
Where buffer is a string and variable is a long or UINT.
You can then display 'buffer' on the LCD.
Jonny
The NumberToHex function will also work with Long variable types to give you a hexadecimal string you can send to the LCD.
STibor
Post by STibor »
Decision errors when testing two variables.
a = 1 AND b = 64 then c = 4
decision.fcf
(10 KiB) Downloaded 374 times
Hi STibor
When using multiple conditions and using 'AND' you will need to use brackets.
Try either
(a = 1) AND (b = 64)
or
you should be able to use a = 1 && b = 64
since though discussions with MM staff it is generally accepted that AND should be use for bitwise only.
Whereas && should be used for bytewise operations.
I would recommend
(a = 1) && (b = 64) as the correct format so I don't believe its a bug
Edit after testing I have come to the conclusion that:
(a = 1) AND (b = 64) = bytewise operation
and
a = 1 AND b = 64 is bitwise that's why it does not work!
But
a = 1 AND b = 1 will work since either value is not >1
STibor
Post by STibor »
Thank you for your response.
I wrote Flowcode4.5 program continue in Flowcode5 .
Flowcode5 was only a simulation of a faulty, coded program is good.
decision Flowcode 45.fcf
Flowcode 4.5
(4.5 KiB) Downloaded 313 times
STibor wrote: Flowcode5 was only a simulation of a faulty, coded program is good.
Ah, so a = 1 AND b = 64 works on hardware and not simulation.
So it is a simulation bug, but work round is easy.
I would not have niticed that since if multiple statements I enclose with brackets.
Thanks for that information
JonnyW
Post by JonnyW »
Yes. The Flowcode simulation works on a grammar which defines which order to eveluate the operators in, like the C compiler. I thought I had all the operators in the same order as C but maybe not for AND. I'll check this on Monday. As you say, the workaround is easy, but I hope this does not effect too many legacy programs.
Jonny
If the intention of your code is to check that the value of a is 1 and the value of b is 64, then I recommend you use the "logical" operator "&&" as suggested by Martin. Also, using brackets will help make the code's intention more obvious:
(a = 1) && (b = 64)
STibor
Post by STibor »
Thank you all for your help!
There will be an example-program package to Flowcode5?
Eeprom->Storing and retrieving Long(ULong) variables.
New adc functions. etc.
