Illegal redefinition of symbol: MX_UART_RTS_PORT
This is cause by a bug in the FC5_PIC_RS232.c file.
If 64bit windows go to C:\Program Files (x86)\Flowcode\v5\Components
or
If 32bit windows go to C:\Program Files\Flowcode\v5\Components
Make a copy of FC5_PIC_RS232.c
then replace original with attached file.
Hopefully flowchart that had the above error will compile successfully.
FC5_PIC_RS232.c
(9.43 KiB) Downloaded 388 times
Ondra
Been thanked: 2 times
Re: Illegal redefinition of symbol: MX_UART_RTS_PORT
Post by Ondra »
It compiled Thank. I haven't tested it on the board yet.
Thanks again for your help.
Ondra
Your welcome.
Since I have not tested it on hardware. Hopefully it will work.
Thanks for letting us know. :)
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hello!
Now I discover again that there is an error or a change. Would not it be a good idea, every time there is a correction and place it in the forum for fix. Or is there something I have misunderstood or overlooked :?:
Best regard
Jorgen.
Hi Jorgen,
This error was first reported here:
http://www.matrixmultimedia.com/mmforum ... 65&#p31758
To keep all errors together, so don't have to keep searching, I posted fix in this 'Flowcode V5 Issues' thread along with other fixes.
I also posted a link to here on the thread error was first reported.
I guess its now down to MM from that point.
I thought this way was the way you wanted it to work?
Unless I misread your post?
Post by jgu1 »
Hi Martin! :D
Yes something like that. I think it would be easier if all the fix´s is ​​in the same place. Or finally MM wil make a total update for V.5
Thank you very much.
Jorgen
We will be posting a patch soon. In the meantime we will post quick fixes and workarounds here.
Please keep the issues coming in!
