16F1933 & 16FLF1933 Bugs Corrected
I have altered and posted F16F1933.fcd & 16LF1933.fcd files to correct following issues
1) Timer0. Errors when compiling:
: error: unknown identifier 'T0IE'
: error: invalid operand 'T0IE'
: error: failed to generate expression
: error: invalid operand '<<'
: error: unknown identifier 'T0IF'
: error: invalid operand 'T0IF'
: error: invalid operand '& '
2) ADC channels AN11 - AN13 missing.
3) Unable to select Port E3
4) Since all CCP type PWM can now be used (up to 10 channels), added CCP3 - CCP5 on chip diagram.
If 64bit windows go to C:\Program Files (x86)\Flowcode\v5\FCD
or
If 32bit windows go to C:\Program Files\Flowcode\v5\FCD
Make a copy of F16F1933.fcd & 16LF1933.fcd
then replace originals with attached files.
16LF1933.fcd
(16.97 KiB) Downloaded 241 times
16F1933.fcd
(17 KiB) Downloaded 238 times
Re: 16F1933 & 16FLF1933 Bugs Corrected
Just corrected some more bugs.
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Thanks Martin.
We will collate all these fixes together after the weekend and it will help us decide when it is worthwhile to do a new release.
Jonny
