UART2 compilation problem
When using UART2, you may receive compilation errors such as:
C:\Program Files\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(422:4): error: unknown identifier 'pie4'
The attached files will fix the issue.
As with all fixes in this area, only apply them if you are having this specific problem. All of these fixes will be released soon as a patch.
PIC_CAL_UART.c
copy into Flowcode's "CAL\PIC" folder.
(20.03 KiB) Downloaded 319 times
16L(F)194x.zip
unzip and copy into Flowcode's "FCD" folder.
(17.11 KiB) Downloaded 336 times
ProtonLaser
Has thanked: 6 times
Been thanked: 2 times
Re: UART2 compilation problem
Post by ProtonLaser »
Hi i have a compiling error With the Chip
CHIP: PIC18F26J53
FLOWCODE 5.0 VERSION 5.4.0.0
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(521): error: left operand must be l-value
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(521:13): error: failed to generate expression
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(522): error: left operand must be l-value
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_UART.c(522:13): error: failed to generate expression
What should i do to fix this because i urgently need to use UART2?
I am also trying to use the Peripheral Pin Select feature
Thank you
This issue is being resolved here.
http://www.matrixmultimedia.com/mmforum ... 46&t=12056
