Eb51 zigbee
lewisrendal
Flowcode V4 User
Has thanked: 3 times
Eb51 zigbee
Post by lewisrendal »
Anyone know why the zigbee modules take so long to initilise approx 5 minutes.
Can't be right, then still don't work though ???
Cheers
James
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Eb51 zigbee
Post by JohnCrow »
Hi James
They do take a couple of minutes initialising on my systems. Not done any real tests on setup speed depending on what sort of PIC i use though.
Have you got the system set to verbose, so you can see the messages on the LCDs. Can be a bit disconcerning, just watching a blank LCD for a couple of minutes not knowing if anything is happening.
I did have a few problems getting things the settings just right myself, when I first got the Zigbee boards.
Try my test files, that will at least let you know the hardware is working ok
End Device.c
(40.96 KiB) Downloaded 310 times
Co-Ordinator.fcf
(7 KiB) Downloaded 315 times
lewisrendal
Flowcode V4 User
Re: Eb51 zigbee
Hi John,
Thanks for the relay and help, the Co-ordinator program is fcf but the end node is "c" think maybe the wrong type you posted ?
Can you forward the end node and I will try once more.
Thanks Again
James :)
JohnCrow
Re: Eb51 zigbee
Post by JohnCrow »
Hi James
Sorry Try these. And I posted them before I went to the pub :)
End Device.fcf
(8 KiB) Downloaded 320 times
End Device - Keypad.fcf
(9 KiB) Downloaded 328 times
acted
Re: Eb51 zigbee
Post by acted »
Can you help me programming keypad with pic16f877 flowcode4 to work like a cellphone keypad. with 2(a,b,c,2) 3(d,e,f,4) .......0 as space. Please help me. Thank you in advance.
JohnCrow
Re: Eb51 zigbee
Post by JohnCrow »
Have a look at the GSM test file on MM website
This has the function you are asking for.
The Enter Message Macro is the actual part you need.
http://www.matrixmultimedia.com/lc_inde ... rder=&dir=
Note
be aware the flowchart wont simulate though as it uses a "C code box"
