EB072 ZIF add-on board
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
Does this EB072 ZIF add-on board fits all older versions of EB006?
Kind regards
Jan Lichtenbelt
Re: EB072 ZIF add-on board
Hi Jan,
Yes the add-on fits onto v6 of the EB006 onwards and even v3 of the HP488 Dev board with some of the jumpers moved out of the way.
To reprogram devices without a PSU connected and just using the USB supply you will need a v8 EB006 though we have currently come across a minor issue with this we are currently working on.
Please note that this add-on is a programming tool only. You cannot run the device using the add-on.
i.e. you would use the add-on on the EB006 to reprogram the device and then pop the device out and place it into your own circuitry to test and or run it.
